Stupid Question - What is that rod on the loader?
   / Stupid Question - What is that rod on the loader? #1
Kyle241
Eastern Ontario
Kubota MX5100
Okay, I have to ask not knowing Kioti's well enough and forgetting to ask the dealer when looking at the DK45SE. What is that metal rod on the loader for? I can see me getting that caught on something and bending causing who knows what damage.
   / Stupid Question - What is that rod on the loader? #2
It is the bucket level indicator to help judge the position of the bucket from the operator seat.
   / Stupid Question - What is that rod on the loader? #3
I think you are asking about the bucket level indicator rod? Located on the loader frame ...
Yes, that is it. Anyone else have issues with it getting stuck on tree branches, etc. ? I do a lot of my own firewood collecting and in the trees a lot.
   / Stupid Question - What is that rod on the loader? #5
I am very careful about not bending mine. I am particular about doing nice dirt work and having the bucket flat and level is a must for me.
Plus its a time saver when going from scoop to dump and back you can have the bucket level before you get back to the pile.
   / Stupid Question - What is that rod on the loader? #6
Yep I have one my John Deere. It is handy. I have bent it up bad more times than I can remember on branches and such. I just pull the cotter pin and staighten it out in a vice or on the concrete floor with a hammer. Ready to go for the next round.
Clayton
Thanks everyone. I finally experienced one by test driving a Kubota today, yes I did say Kubota. I am comparing the two brands as while I have a Kubota, I am open to both as they both make nice tractors. Just looking to upgrade to 40+hp.
   / Stupid Question - What is that rod on the loader? #8
When we got our used Kioti home and unloaded my son and I pulled it up to the garage to look it over and weld a hook on the bucket. My son noticed that ther was a bolt not completely tight holding some kind of rod above the bucket. The bolt was tight it just has a shoulder on it so the rod can swivel, but we didn't know that. I told him to get a wrench and tighten the bolt. By the way he is 6'4" and strong like a bull. Well, he gave the wrench a mighty turn and twisted the head off of the bolt :ashamed:
The rod is still standing in the corner of my garage. One of these days I will put it back on I guess.
   / Stupid Question - What is that rod on the loader? #9
I bent the crap out of it and took it off. It was annoying that I had to stop what I was doing and take time to remove it. I can't say that it was any help when it was there as I never looked at it. Now that it is gone I don't miss it.
   / Stupid Question - What is that rod on the loader? #10
o2batsea, Just wondering how long it took to remove it ?? Was that a $90 job or more ??
   / Stupid Question - What is that rod on the loader? #12
I've been toying with the idea of adding a level indicator for my old Ford. It wouldn't be hard to make one and it could be a nice addition when doing loader work. I just have to decide how bad I want to add something else to snag on all the brush. :rolleyes:
Joe
   / Stupid Question - What is that rod on the loader? #13
+1
It is invaluable when do any kind of dirt work, backdragging, or even trying to scoop a rock into the bucket.
   / Stupid Question - What is that rod on the loader? #14
There is such an indicator on my JD 3520 and I've managed not to get it caught in the brush or branches so far. I've tried putting color marks on it corresponding to various positions of the bucket but have never found it really useful. I've done quite a lot of dirt work, but, at least on an open station, there is nothing like looking at the top edge of the bucket to control its position. Besides the indicator emits all sorts of squeaking noises I could do without.
   / Stupid Question - What is that rod on the loader? #15
My Mahindra has the typical rod/tube indicator too and when the tractor was new I got on a nice level concrete pad and set the bucket down nice & level and marked the rod accurately even with the top of the tube. I removed the rod and carefully ground a shallow groove around the rod at this point and then painted inside that groove with some bright yellow paint - my tractor/loader are red so I had a clearly visible mark to go by for a perfectly level bucket to learn loader operation on.
The two loader pins that my rod/tube mounts to have large "E" clips that remove easily so the rod/tube assy comes off quickly & easily for those repairs when needed. They also stay greased well since they are the loader pins. You can leave the rod inside the tube and straighten the tube with a hammer on a nice flat metal surface - I've used the top edge of my boxblade and my bucket before to hammer it straight in the field. Then you can remove the rod and do a final straightening on it the same way. I quit painting the groove quite a few years ago, after 9 years and right at 2000 hours I can just glance at the amount of rod exposed and know where my bucket is at and yes, I use it all the time still instead of looking at the bucket itself.
   / Stupid Question - What is that rod on the loader? #16
Wait, wait, i gotta stop laughing!
I would say it took a lot less time to remove than for you to think up that post.
   / Stupid Question - What is that rod on the loader? #17
You may need to spray that rod every once in awhile, kinda a metal on metal issue. Mine has a squeal detector on it, when it starts to squeal when I curl the bucket it means it is time to lubricate it again. A little wd40 or other spray lubricant will work just fine.
   / Stupid Question - What is that rod on the loader? #18
I have a friend that just shouldn't have access to tools as he breaks everything. If a little is good, a lot is better..................right? We do not let him near our tools, or machinery anymore.
   / Stupid Question - What is that rod on the loader? #19
Yep. I completely destroyed the first one and have managed to bend the replacement. It's coming off and I don't think I will reinstall it except when I specifically need it to grade with the bucket.
   / Stupid Question - What is that rod on the loader? #20
What he said x2
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2004 FORD F-350 XL DUALLY CREW CAB FLATBED TRUCK (A59823)
2004 FORD F-350 XL...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
iDrive TDS-2010H...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
