Is it possible for a tractor to have limited slip?
   / Is it possible for a tractor to have limited slip? #1
dcyrilc
Super Member
Woodinville, Washington
John Deere 2240 MFWD
I just did some serious pushing with my tractor last night. Trying to put a tri-axle trailer with 15K# of hay on it back into the barn through the mud. What I found interesting was that when I really got on the throttle, all the tires would spin and throw mud and rock. I've never heard of a tractor having posi/ limited slip, but this is sure how it acted. At low throttle only one rear tire would spin, but when I got on it they would both spin as well as both fronts were spinning too.
My axle lock is non-functional and I was considering digging into it to repair it, but now I'm not sure I want to. This little 50HP 2240 tractor with the duels on it is really a beast. The right side of the trailer never got the axles on top of the dirt, but just cut a path through it. I was pushing dirt/mud with the axles and the frame is only 2" off the ground. The tractor was walking 4 feet sideways back and forth pushing the trailer into the barn. What a ride.:laughing: Not quite the result I was hoping for, but the hay's under cover at least.
Anyway, anyone have thoughts on why I would have power to all 4 (6) tires at the same time?
   / Is it possible for a tractor to have limited slip? #2
Same happens on cars/trucks that don't have lim slip axles.
If you get enough power to an open axle it will spin both tires, trouble is you aren't getting very much actual BITE - but it looks good (-:
   / Is it possible for a tractor to have limited slip? #3
I wish I had a link to a TV news story I saw last week where a Bimmer owner spun his tires fast and long enough on the ice to catch his car on fire.
I'm not sure where the exact ignition point was; but it was an interesting video.
   / Is it possible for a tractor to have limited slip? #4
Here's the video on YouTube.
dcyrilc, if your tires were actually getting traction then they would not all of been spinning at the same time unless you had the differential locked. I know I have a foot pedal to manually lock the rear differential but the front is open. I don't know of any tractors with a locking front differential.
   / Is it possible for a tractor to have limited slip? #5
Here is the deal, if traction is equal, then all the wheels can spin, you were in a low traction situation, but it is low traction for all axle's so they all recieved equal power. One wheel on each axle can stay motionless or near motionless when it has good traction and the other side has poor traction causing the poor traction wheel to spin at 2X the speed it would normally turn because it is being spun up also by the rotation of the spyder gears which are now turning on their jackshafts as well as the normal rotation of the differential frame. Keep in mind when this situation is happening that the spyder gears are just on bushings and are not made to spin a lot and can get pretty hot. Normally they do not spin at all when traction is equal and you are going in a straight line. When turning they rotate slowly to make up the difference in the wheel track lines, and speed up the outside track wheel. This is what prevents you from "scubbing" when making a turn. I dont know of any CUTS that have any of the limited slip schemes in them. But I could be wrong. When we were kids, (long time ago) we used to abuse our high powered cars on a regular basis. Normally when spinning our tires on the pavement only one tire would leave the beloved J hook black mark. This was usually accomplished by letting the car roll backward down a hill, and then flooring it. But some times only occasionly you would get a perfect 2 J hook marks. This occured when the road conditions allowed a perfect match up in traction conditions on both tires. Then when GM introduced the Posi-Traction limited slip rear axle in 1965 all bets were off. they had a clutch pack arrangement in the rear end, that locked it up and burned both tires. More than one set of spyder gears turned blue, and sometimes locked up on their shafts. :laughing: Not smart, but we did it.
James K0UA
   / Is it possible for a tractor to have limited slip? #6
When we were kids, (long time ago) we used to abuse our high powered cars on a regular basis. Normally when spinning our tires on the pavement only one tire would leave the beloved J hook black mark. This was usually accomplished by letting the car roll backward down a hill, and then flooring it. But some times only occasionly you would get a perfect 2 J hook marks....
James K0UA
We called that a "dummy drop." We would put the car in reverse, then without stopping throw it in L1 (or whatever gear is on the other side of N) and floor it. It was more fun on country roads where a lot of tar had risen to the surface in patches. Man that was fun, but those poor cars took a beating.
   / Is it possible for a tractor to have limited slip? #7
When doing those burn off's with one wheel near motionless, and one tire spinning, usually the speedometer indicated 120 MPH, as the speedo is driven by a gear in the transmission, so the driveline was going 120 and one tire was near motionless, then it follows that the spinning tire is going 240 MPH. It is a wonder that more of those old tires did not come apart.
James K0UA
   / Is it possible for a tractor to have limited slip? #8
when the diff is heavily worn, you can get binding in the sun gears when you apply a lot of power. It effectively locks the diff. That is what you are seeing.
I ran a street car at the dragstrip for a number of years like this. It actually worked better than the posi I eventually replaced it with.
Hmmm......
...all interesting thoughts. I would be really suprised if I had perfectly distributed lack of traction. Especially once I got down to the gravel. So far, tcartwri's thoughts make the most sense.
I don't think I have the experiance to recognise worn gears from new gears, but I do have a picture from when I had the 3PH off to rebuild it.
As for the diff lock, I have the pedal also, but it doesn't do anything. The dealer gave me some ideas what to look for to assess what will be needed to repair it. I'll be looking at that this spring after it warms up sime since my shop isn't heated.
   / Is it possible for a tractor to have limited slip? #10
The Kubota M series from 70 HP up has limited slip on the front axle and a real lock lever. All four tires will spin under the right (or wrong) conditions.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
2012 Kenworth T800 Heavy Haul Truck, VIN # 1XKDD40X6CR301872 (A57453)
2012 Kenworth T800...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
Misc Stihl Lawn Equipment (A56860)
Misc Stihl Lawn...
