Concrete prices per yard
/ Concrete prices per yard #1
gregfender
Gold Member
Marion, NC
Kubota L2501 HST
Could anyone give me a general idea what the cost per yard is for concrete. I am looking to pour the floor of pole barn.
/ Concrete prices per yard #2
In the SF Bay area it is now in the $120-140 range, depending on specific type.
Southern Oregon is about $10 less per yard.
/ Concrete prices per yard #3
Arkansas 90-110 per yard depending on mix.
/ Concrete prices per yard #4
This past summer I paid $108 per yard including tax and fees for 4000 psi in east central Alabama.
Scott
/ Concrete prices per yard #5
Around here in the $115-$125 range, but if you are pouring a good size slab, call your local concrete companies, ask for a contractor sales person, tell them you are acting as your own contractor and are looking for the best price you can get. I did that and was able to get a contractor rate of $92.
/ Concrete prices per yard #6
I would budget $125 and add 10-15% extra yrds to make sure you have enough. Hopefully you can get it a cheaper and based on your location I am guessing you'll be able to shave $10 off that. You can always just call your local plant, they are happy to provide prices.
/ Concrete prices per yard #8
I can buy it myself for $83 per yard. I can buy it through my finisher for $76 per yard.
/ Concrete prices per yard #9
Poured the pad for my pole garage 2 summers ago.
12 yards total bill was $1230 on the money.
So $102.50 per yard.
That was including delivery, 6 bag mix, and retarder put in:confused2:
Take my advise, If you plan on doing it yourself with a few buddies, DONT do it in the middle of july
/ Concrete prices per yard #10
I was told awhile back...the proper terminology is "lay" concrete...not pour. When, talking to pro's..they seem to have more respect..or look at you like you know what your doing if you use the proper terminology:confused3:
/ Concrete prices per yard #11
Actually the correct terminology is PLACE it. You dont really pour it or lay it if you are smart, you place it where you want it so you dont have to shovel it or use a concrete"comealong" to move it from place to place.
/ Concrete prices per yard #12
As for pricing, there are so many variables with concrete, you need to specify what strength you want (most slabs use either 3000 or 4000) and I like to spec 4000 and hope the supplier gives you what you ask for. They will short you if they know you arent going to pull a slump and make test cylinders and lets face it how many homeowners do that. Then you need to decide if you need a plasticizer to make it more fluid without adding a bunch of water which decreases the strength. What kind of cement do you want, type 3 or do you need type 4 for sulfate and chloride resistance. Do you want nylon mesh particles in it to help with crack resistance, do you want a retarder to keep it from flashing off (need this if pouring in the heat of summer). All these add a significant amount to the cost. Your local supplier will tell you what it cost and he may even give the the contractors discount if you are ordering a full 8-10 yard truck or multiples of that. If not, you will be paying extra for the trucking for partial loads.
/ Concrete prices per yard #13
oops...your right! Sorry. My tongue got behind my eyetooth and I couldnt see what i was saying :)
/ Concrete prices per yard #14
I was told the other day it was in the low eighties right now. That's about a twenty percent drop from a year ago when we "poured" over a hundred yards.
One of the problems with terminology here is you have at least a national audience, most of the time it's international. Correcting terms is like correcting spelling on the internet... there's only one person that looks like, well,.........
Thanks for all the info. The more I thought about it, the more I realized I should have been a little more specific...considering you guys are a wealth of info.
I am building a small pole barn, 16x20. Since it's not a huge place, I wanted to go with concrete instead of a gravel floor in hope that i will finish up the inside and eventually heat and cool it so I will have a working shop. About the heavest thing I will be putting in it is a tractor - no more than ~4000lbs.
I live in the western NC foothills and while we do get some cold days, extreme temps are rare. The site has good soil and good drainage.
That being said, I was thinking of a 4" pad with a 6" to 8" apron. Since I have never done concrete work before, I am going to prep and level the site, put up form boards, then let the professionals do their thing. Of course if some of the other steps are simple, I might do more to keep the cost down.
Any info/help/tips, etc would be HUGELY appreciated.
/ Concrete prices per yard #16
Mine was slightly larger than yours but I added an 18 x 32 pole barn plus a 2 x 10 apron attached to the back of my garage. It took about 13 yard which cost about $1200. I used 4000 psi fiberglass reinforced mix. I paid the pros (friends of a friend) to finish it at a good price. I also did all the prep work, and framing myself.
/ Concrete prices per yard #17
Watching UFC sat night with a buddy who works at a large union const place. He has alot of union provided toughman paraphinalia, his stocking hat is embroidered "Pour N Crete"
I am pretty sure its called pouring concrete round here.
/ Concrete prices per yard #18
...I am pretty sure its called pouring concrete round here.
I think concrete is "poured" all over the west coast.
I am not a "pro", but a very advanced amateur -- my lifetime accomplishment is about 250 yards on my own, and a lot more if I count the stuff I hired pros to do for me. At this point in my life I would rather hire a couple of day laborers to help with forming for wall and footers. For slabs I would also need a finisher on the day of the pour.
At least a crew I hire will do it my way instead of giving me a bunch of lip about how we don't really need doobies--just pull up the bar (a failure every time it is done), or that rebar doesn't really have to be clean, or that mesh is as good as rebar, or that diesel sprayed on the forms doesn't hurt if it gets on the rebar, and on and on.
/ Concrete prices per yard #19
Gregfender-
In my part of Texas (between Huntsville and College Station) you can expect to start at about $110 for 3000 psi mix and then the sky is the limit as you add retarders, colorants, air entraining additives, fibers, increase the psi etc....
You can also expect small jobs to have a "short load" fee for anything less than a full truck, mileage charges for more than 15 miles or so delivery, and about $60 an hour or part thereof "waiting" charges if you keep the truck waiting more than 10 min to unload.
As someone who has poured more concrete out of the cuffs of his dungarees than most folks have walked over, I would HIGHLY recommend you find a well-established local batch plant and go visit around afternoon coffee time with a box of donuts under your arm and see what they have to offer...
...batching concrete is as much art as an exact science....an experienced operator will save you money in the long run by providing just the right mix for your particular application.
You may be surprised to find some of the operators are more than willing to work with a smaller "owner-builder" and work your project into the schedule along with his larger projects....and if you group a few smaller projects together you can avoid the "short load" fees....
To avoid the "waiting" fees, tight scheduling is paramount...you are going to need a lot of help "pouring/placing/putting/sticking/dumping/pumping/setting" this stuff...and labor is the costly issue here...even a bunch of good friends at least needs to be fed and "watered"....a good operator will make you or break you...
Do as much prep work as you can...if you have not done a large pour before, a trip to the Big Box store or the internet will provide a torrent of books on the subject...if you already know how to move dirt with your tractor, you are halfway there, and putting up form-boards, installing some plastic, rebar or re-wire and getting ready for the trucks to arrive AIN'T rocket science...
Check around with your friends and family...you might be lucky enough to find someone who has done this work and would be willing to be your 'boots on the ground" advisor...
A couple of Rules....
Always overbuild a LITTLE...put in a little heavier or closer spaced bar or wire or buy a little richer mix when you can afford it, but don't get carried away, you're building a slab to park a tractor on, not the Interstate...
....and always keep enough plastic on hand to cover your pour when (not IF) it rains....
Anyway....welcome aboard, good luck on the project and keep posting...
Terry :D
/ Concrete prices per yard #20
Pouring concrete is common name for it on construction projects, however the guide for all concrete work ACI (American Concrete Institute) in their many CODE books that governs everything from design to how to put it in the form calls it PLACING. So when talking to an engineer you are placing, if talking to the guy down in the form on the construction site, he will be pouring concrete while the guy on the superslab that is dumping 0" slump concrete from a dump truck into machine to auger it in to place, vibrate it and scread it smooth may indeed be laying concrete.
2016 BOBCAT E35I EXCAVATOR (A60429)
2016 BOBCAT E35I...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2012 HYUNDAI  HL740-9 WHEEL LOADER (A58214)
2012 HYUNDAI...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
