Ideas on cutting steel corrugated pipe
   / Ideas on cutting steel corrugated pipe #1
955Lincoln
Gold Member
South PA/Western MD
What would be the best and fastest way to cut 5' diameter corrugated drain pipe? I need to make about 40 cuts.
Thanks!
   / Ideas on cutting steel corrugated pipe #2
Plasma if you have one, or a torch. Be aware of fumes if it's galvanized.
Large chop saw would work too for a cleaner looking cut, but a plasma would be quick.
   / Ideas on cutting steel corrugated pipe #4
Plastic or metal?
Steve
He mentioned steel in the title.
And I agree, torches or plasma if avaliable.
If not, a sawzall and fine toothed blade wouldn't do too bad either.
   / Ideas on cutting steel corrugated pipe #6
The old fashioned sazall with a high quality blade or a mini gringer with a 12 pack of zip disks.
Craig Clayton
   / Ideas on cutting steel corrugated pipe #7
Some thing came to mind are these cuts going to be made on a fixed in place pipe or slices off of turnable pipes.?
Craig Clayton
Craig Clayton
Not fixed, just loose galvanized steel pipe. Need a quick easy way to make about 40 4' long sections. Keep in mind guys, 5 foot diameter, not inches.
   / Ideas on cutting steel corrugated pipe #9
a gas cut off saw with a metal blade
or a electric curricular saw with the right blade be prepared for hot chips and noise
swkJgjcIrAMN6Kd0J4B8mW96KKeOeSTT3GN7vr0_mIL21wtOPkeo9iI1LwM-Tr-UEQGG3StiBBXRprnmn08VMqKy2emLBkYUkdKBYtJUnsDvmqB5E4sdNbzOlPYhfisoz2C7UnN58m7HmYUWw7Ak9GZsAjLC0ZgEkfG4-tekEClf
Morse CSM72540SC Circular Saw Blade 7.25 in 40T Metal Cut
for gas wells????
tom
   / Ideas on cutting steel corrugated pipe #10
I think you need to make a rolling jig to have them turn slowly. So 40 pieces at 4' means 160' of stock. Now you have the lengths themselves say 20'. The rolling jig needs to be able to support down to the last 4'.
Another way is to chase them across the floor so PIE x D=15.7 ' of floor space.
For the rolling jig I would suggest several sets of 8" hard rubber fixed caster wheels bolted to the floor. To turn them you could wrap a strap around and pull it up with a hoist.
Craig Clayton
2015 Ford F-450 Crew Cab Knapheide Service Truck (A53422)
2015 Ford F-450...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
Peterbilt (A51692)
Peterbilt (A51692)
CATERPILLAR CS54B ROLLER (A52707)
CATERPILLAR CS54B...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
1305 (A57192)
1305 (A57192)
