Best RPM for Fuel Economy and FEL work
   / Best RPM for Fuel Economy and FEL work #1
CowwFace
Gold Member
Conifer, Colorado
Kioti DK45SE HST, 401FEL, RB40-96 pivoting Rear Blade
Hey List,
What do you guys typically run your DK40, 45, 50's at for best fuel economy? I typically run mine at a bit over 2k and that seems to give me good power and fast hydraulic mvt. On my tach there is a little red triangle, and I've always assumed this is were the PTO is running at the 540rpm rating? Or is that something else?
I was reading a post in the New Holland thread and I thought it was a great question...
Tractor on,
   / Best RPM for Fuel Economy and FEL work #2
Hi CowwFace,
You are right that the red mark on the Tach represents 540 rpm on the PTO.
I like to operate my DK 40se at just over 2000 rpm. The engine doesn't seem to be working so hard and is much quieter. Even when using my 74 inch snow blower I usually don't rev it up to the 2600 and have no trouble moving snow. Travel speed across the road is faster at full RPM and that is about the only time I rev my Kioti that high. I notice a little hydraulic wine at full throttle also.
I only have 80 hours on mine so I'm still learning.
Take care.
   / Best RPM for Fuel Economy and FEL work #3
I also run my DK40se at 2000-2100 for most mowing and 1800-1900 for backhoe or routine FEL work. I use full PTO speed only when mowing thick spring grass or when tilling new areas.
My rationale is simply that the tractor does the work at those speeds without lugging down and I prefer the lower engine volume. I have no idea if it really saves much fuel or engine wear.
   / Best RPM for Fuel Economy and FEL work #4
I was wondering the same thing with my CK-20 with snow plowing and snowblowing.
BigTurk is about where I am...anyone else with the same question on the smaller models?
Jon
   / Best RPM for Fuel Economy and FEL work #5
I used basically the same RPM ranges with my CK20. The only difference was if I tried to mow in high range I needed to use PTO RPMs.
   / Best RPM for Fuel Economy and FEL work #6
The only time I run near full throttle is when I'm doing a lot of loader work and want to work quickly. Loader cycle time is faster, the higher the RPMs. Also full throttle for chipper. I don't mow with it. Backhoe 1600 for leisure, 1900 for "fast" work.
Scraper 2000 unless going up hill. Boxblade fully engaged: full throttle.
Fuel usage goes up markedly above 2000 or so.
Putzing around 1600 - 1800 on my gear. HST's might want to be a little faster to maintain good tranny pressure.
   / Best RPM for Fuel Economy and FEL work #7
I run mine more in the 1800-2000 range most of the time. When doing loader work or anything not steady state, I use the foot throttle and vary rpm, but rarely go over 2000.
   / Best RPM for Fuel Economy and FEL work #8
The PTO speed is usually set to maximum torque the engine can produce. It is also the speed of the best specific fuel consumption [ounces/HP/hour]. My tractor has Kubota 1501 engine and I run it above 2000 rpm most of the time but very seldom over PTO speed.
   / Best RPM for Fuel Economy and FEL work #9
Good question. I have a CK 27 HST. Read the posted RPMs, but how many hours or GPH can you expect to get running 1800 to 2000 RPMs? I must have missed something??? Thank you very much! KK
   / Best RPM for Fuel Economy and FEL work #10
I've only done this once or twice. I was getting about 7 hours at or near PTO HP on a tank. Tank never ran dry, but probably close, like 6 -7 gallons. From what I've been reading that is about what to expect, right around .8 - 1 gallon per hour.
2023 WESSEX RMX500 LOT IDENTIFIER 44 (A53084)
2023 WESSEX RMX500...
MURRAY 22" GAS PUSH MOWER (A51248)
MURRAY 22" GAS...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A53472)
2012 NEW HOLLAND...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
