20 20
Elite Member
Do you think that is to hard on the machine?
In a word YES, it can be, not saying lighter loads would be an issue but heavier loads could cause premature wear down the road. Another thing to keep in the back of your mind is safety/balance{again I'm sure you know this} carrying something to the side like that does give a "tip factor".
I liked the way I could position the tree parallel to the tractor so I could move it up the driveway.
I can relate to that I use a mini excavator the same way to move logs out to my trailer. I like the fact that I can move them through tight spots and not drag them through dirt. The logs get used for milling, clean logs are much better then dirt covered.
