private/noncom hauling and DOT involvement
   / private/noncom hauling and DOT involvement #22
If everyone read the "applicability", sections 383.3 and 390.3, it makes a lot more sense.
In a nutshell the 26k is what requires a CDL is all.
All this is for vehicles engaged in commerce per the feds, the feds also say personal is exempt.
It appears that where arsenix lives is a tad bit overboard though.
I am glad MI kinda follows the feds!!!
  • Intrastate_USDOT_FAQs_189910_7.pdf
   / private/noncom hauling and DOT involvement #23
Personal use is exempt from part 390 but not part 383.
Use of the term "personal use" is used pretty liberally around here.
   / private/noncom hauling and DOT involvement #24
Duff,
If I read those 2 sections correctly, do they not say for operating a CMV????
A personal pickup with trailer to haul whatever for your own use where there is no compensation for hauling should be exempt, (except in Maryland)
If you haul someones tractor and accept payment now you would be in commerce.
Even at 26k it still applies to a CMV only.
Here in MI for a small CMV we have a chauffeurs license for the 10k to 26k range.
We had that before the CDL and at that time the chauffeur covered eveything.
   / private/noncom hauling and DOT involvement #25
The first line from 383.3 follows......
(a) The rules in this part apply to every person who operates a commercial motor vehicle (CMV) in interstate, foreign, or intrastate commerce, to all employers of such persons, and to all States.
   / private/noncom hauling and DOT involvement #26
   / private/noncom hauling and DOT involvement #27
Here smart azz, Maryland Motor Carrier Frequently Asked Questions. Pay special attention to section 5 and 8. It doesnt matter if you have an RV or a truck full of unicorns, over 10k and you have to weigh.
5. What is the definition of a commercial vehicle?
The Federal Motor Carrier Safety Regulations have defined a commercial motor vehicle (CMV) as noted below. Maryland has adopted this definition for commercial vehicles that operate only within state boundaries (intrastate).
CMV definition:
Commercial motor vehicle means any vehicle operated in interstate commerce to transport passengers or property when the vehicle
(1) Has a gross vehicle weight rating or gross combination weight rating, or gross vehicle weight or gross combination weight, of 10,001 pounds or more, whichever is greater; or
(2) Is designed or used to transport more than 8 passengers (including the driver) for compensation; or
(3) Is designed or used to transport more than 15 passengers, including the driver, and is not used to transport passengers for compensation; or
(4) Is used in transporting hazardous?materials?in a quantity requiring placarding.
8. What vehicles must go through weigh stations in Maryland?
All vehicles with a gross vehicle weight or gross vehicle weight rating of greater than 10,000 pounds must stop at open weigh stations. Only vehicles that are operating in commerce will be subject to a safety inspection.
9. Does a rental truck hauling personal property have to stop at weigh stations?
Yes, if it weighs more than 10,000 pounds. However, these vehicles will not be subject to a safety inspection.
Happy? Why dont YOU do some searching next time before running your mouth.
Ok. Maybe you should read what you post:
CMV definition:
(4) Is used in transporting hazardous materials in a quantity requiring placarding.
Pay special attention to:
"Commercial motor vehicle means any vehicle operated in interstate commerce to transport passengers or property when the vehicle" Which means not personal use vehicles. Interesting that you cited that yourself, even though it doesn't agree with your statement.
So, it is not clear if the statement further down the document about weigh stations applies to all vehicles or only all vehicles covered by that document. Myself, I wouldn't read the "Maryland Motor Carrier Frequently Asked Questions" for information about my personal vehicles.
   / private/noncom hauling and DOT involvement #28
I think the 10,001 is for interstate, not intrastate. At least that's what I believe it is in CT. If I go to MA to clean someone's gutters with my 12,500# GVW Ram 3500 I would require DOT numbers on the truck. Not sure what else I would have to comply with though, logs, med card etc.
If I stay within state borders I don't need DOT number.
JB.
   / private/noncom hauling and DOT involvement #29
Duff,
Kevin, look at the USDOT defintion of "commerce". It has nothng to do with compensation.
   / private/noncom hauling and DOT involvement #30
Look at item 2 from the MI link I posted.
What is the defintion of "personal use"?
What about hauling race cars/pulling trucks?
How about hauling tools to a rental property?
I haul my personal things all the time and don't get paid for it but I am a private carrier.
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
2019 CATERPILLAR 226D SKID STEER (A52709)
2019 CATERPILLAR...
20ft x 30ft Steel Carport (New/Unused) (A59225)
20ft x 30ft Steel...
202479 (A54757)
202479 (A54757)
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2008 Caterpillar G23G Scraper, S/N CAT0634GADBY00493, Cat Turbo Diesel, 12,763 Hours Indicated, (A59076)
2008 Caterpillar...
