Newbee to metal fabrication with scrap Q's
   / Newbee to metal fabrication with scrap Q's #1
LotsofGreenGrass
Gallatin, TN
John Deere L110 and Mahindra 2816 4wd
Hi Guys!
I can think of few better days than building something to play with. Anyway..
I have never bought scrap steel before. I have no clue what to look for as far as quality. For that matter, I could easily get ripped off by sounding like an idiot.
What do recommend I say to a scrap dealer? "I need some scrap?" Do they typically sort it by type, grade, etc? :confused:
I want to build and FEL for a 28 horse Mahindra.
Thank you in advance for your response!
   / Newbee to metal fabrication with scrap Q's #2
Good Question I would like to build a FEL for my 30 HP Belarus 250AS.
   / Newbee to metal fabrication with scrap Q's #3
You need to become buddys with someone in the metal fabricating business....they chuck out stuff all the time but don't let anyone near their dumpsters (liability).......they don't get much money for it so anything they get is extra.....
I have a business next door to one and every few days my guys will peek in to see what's for leftovers.......new cut offs......
Many times with the right inquiry (and a little cash) they may just cut off something for you (if you are nice/lucky)
   / Newbee to metal fabrication with scrap Q's #4
For what your trying to build, a few steel yards still have cutoff piles. These are remnant pieces cut off of a special order. Often times they can be cheaper that a typical $$ per stick or piece cost. On the other hand, stuff that has been laying around may be rusty enough that the $$ savings may not be worth the effort cleaning it up. As most people would say, it is simply being at the right place at the right time.
   / Newbee to metal fabrication with scrap Q's #5
The first question you need to ask is if they even sell scrap to the public. As mentioned, a lot of salvage yards and fab shops DONT let anyone they dont know buy the scrap due to the liability of you kigging through a pile/dumpster of a bunch of sharp/rusty steel.
And sometimes, just buying new might be the way to go. If you carefully plan everything and know EXACTALLY what you need, a loader/frame should weigh more than ~700-800lbs for your tractor. And new steel is usually .50-.60 per lb. So you are only talking about roughly $400. To find what you need in scrap might cost you $100. So is saving $300 worth the fact that it may be rusted and not exactally what you want and you have to comprimise?
   / Newbee to metal fabrication with scrap Q's #6
many scrap yards will sort useable metal. IE.. box tube, angle, rod.. square stock.. etc.
check around.. see what they got.
getting enough scrap to build a laoder may be hard. some pieces will be bigger than scrap that is normally discarded or sold.
soundguy
   / Newbee to metal fabrication with scrap Q's #7
The steel place I buy from has a scrap yard... It is about .25 cents a lbs cheaper..
But I am in a major city.... buy from SSS steel..
   / Newbee to metal fabrication with scrap Q's #8
Note the difference between new scrap (leftovers from a new job that may be marked) and old scrap at a recycle yard. Especially with old scrap, you will have to take your chances on the make-up of the steel. Would hate to spend the time and energy building a loader just to have it crumple the first time you use it.
   / Newbee to metal fabrication with scrap Q's #9
When I buy steel I usually just call around, and get the whole piece, If you need it cut they will do that for you. If you have a list they can give you an exact price, sometimes it is worth the trip to go to multiple yards and see what they have in there rack of short pieces, and modify you design to fit what is available cheap, then pay full price for what you need that is not available.
I also am always looking to see what people have and are willing to trade for.
   / Newbee to metal fabrication with scrap Q's #10
Most of the stuff you're going to buy from the scrap yards, etc is going to be A36 mild steel, which should be fine for your project. This stuff is common, and most of us use it or something similar for our projects.
Find yourself a good steel book from Ryerson or R & S to get shapes, dimensions, and weights. Ryerson and R & S are big outfits that sell large quantities and won't deal with us lowly little homeowners/hobbyists/etc.
Triple-S Steel
Ryerson - The Strength in Metal
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53472)
2023 NEW HOLLAND...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
2022 Freightliner M2 106 Medium Duty Rollback Truck, VIN # 1FVACXFC5NHNM7347 (A51572)
2022 Freightliner...
