Newbee to metal fabrication with scrap Q's
   / Newbee to metal fabrication with scrap Q's #11
I have a business next door to one and every few days my guys will peek in to see what's for leftovers.......new cut offs......
Watch out ! That guy is mean'r than he looks !! ;);)
   / Newbee to metal fabrication with scrap Q's #12
Go look a a loader to get an idea what they are made of. Rectangle tubing, pipe and shaft for pivot points flat plate for gussets a big plate to make a bucket. Some loader frames are made from pipe.
   / Newbee to metal fabrication with scrap Q's #13
good old jungle gym loaders.. :)
soundguy
   / Newbee to metal fabrication with scrap Q's #15
gives you a workout too.. protects from limbs.. :)
   / Newbee to metal fabrication with scrap Q's #16
I can't help but think that since you are a newbie to scrap metal, that you must also be somewhat new to welding itself. I've been welding for some time and wouldn't undertake building a loader with the experience I have. My hunch is you're biting off more than you can chew. Sorry.
   / Newbee to metal fabrication with scrap Q's #17
In my experience working as a welder (for about 2 years) if you do a decent job of it, most of your time is going to be spent laying out the steel, cutting, notching, beveling, in other words - prep work before you even strike an arc. With all that time invested - and building a FEL is going to mean a lot of time invested - saving a few dollars to get steel that is of questionable condition and quality may not be you best option. All depends on how you value your time and how much you can afford to fritter away cutting up and fixing things if it doesn't work right the first time. Think hard about how you approach it before you dive in. You could save yourself a lot of frustration and even money if you make sure any used steel you buy isn't compromised by being the wrong type, internal rust or strain/cracking from deformation.
   / Newbee to metal fabrication with scrap Q's #18
Long before you go looking for steel you want to look around at dealer lots not the new stuff the junk in the back, at auctions, look what people have fabricated, what they used, what seems to have worked. I do that all the time even if I have no plans to build something. Seeing a good idea, and then when you see a part, that was used, you might want to keep it rather than throw it out. I wish I would have kept, a few truck tie rod ends for use as base pivots.
You will also see things that did not work, that is the information that can save you a lot of time and money. Better to learn from others mistakes.
The Quality of everything you do depends on the amount of time you are going to use it. Spending thousands on something you use once is a loosing proposition, but scabbing something that will do the job from a junk pile that takes vision.
Just a thought!
   / Newbee to metal fabrication with scrap Q's #19
I consider myself a DIY type and anytime I can cut the price by 75% just by investing my time I'll probably go for it, then use the leftover money(?) to build something else.
   / Newbee to metal fabrication with scrap Q's #20
OK I will bite what is BYI?
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
2013 FORD F550 SHUTTLE BUS (A52576)
2013 FORD F550...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
