smoke out vent tube
   / smoke out vent tube #11
It is not uncommon to get some "smoke" out of crankcase vent tube on a higher hour engine. Especially under heavy load. It would be a good idea to check and monitor your fluids as suggested above. If everything looks alright, you are probably just experiencing a little blow-by under load.
so is it possible to not have antifreeze in the oilpan and still have a bad headgasket? i dont seem to be going through coolant. the engine does not overheat either. i always thought a blown gasket resulted in overheating.
   / smoke out vent tube #13
You are correct. The kicker on this one is the milky snot in the vent tube. Sure sign of anti freeze.
   / smoke out vent tube #14
May need some new piston and liners soon, that should make it a new engine so to speak.
   / smoke out vent tube #15
If it starts good, I wouldnt worry about it. Make sure the engine temp is up where it's suppose to be. Too cool engine temp will cause milky condensation in the tube too. I have irrigation engines that do it and never add water.
   / smoke out vent tube #16
smoke comes out of a vent tube on my 2010 when i strain the engine. the tube is on the right side of the engine and it vents straight down to under the engine. is it a serious problem or just an old engine. it does not smoke out the stack when this happens. any thoughts?
If it's not using coolant, then it's not coolant related.
Sounds like normal crankcase vapor for an older engine, since you said it use's a quart of oil in 10 to 15 hrs. All engines new or old have pressure in the crankcase and some brands of oil burn off faster then others. You could try using a different brand of oil next oil change or add some Lucas Oil Stabilizer/Treatment to the oil.
If it has good power & starts good, I'd run it.
One last thing the harder you work an engine the more vapor you'll get out of the vent tube. On newer engines that vapor is drawn back into the intake and burned again.
How many Hrs on this engine ???
   / smoke out vent tube #17
If the antifreeze keeps it's level the cooling system part should be ok. [as has been stated]
Also the temperature remains within its operating range.
Oil level goes down with use can be quite normal.
If it sits for long periods of time condensation may accumulated in the oil pan. This will vapour off out the crankcase breather as the engine heats up.
One suggestion is the valve oil seals are getting worn and brittle which will allow some combustion vapours by. This will show up at the crankcase breather vent just as you have described. Under load it would be more evident. It may also be where the oil is being used.
The chances are all is good and the tractor can be used.:)
Please note that I have no mechanical qualifications but do own an adjustable spanner and have scarred knuckles.:laughing:
about 6800 according to the meter. i bought the tractor last year. it sat all winter long and started up as soon as i turned the key last week. it does have decent power for a 45 year old tractor. it did smoke out the vapor tube some last year but seemed worse yesterday when i was working her a little. maybe it is condensation in the oil from the winter. i live in syracuse ny so the winter was very cold and long and it sat in the barn for over 5 months. i put it away with clean oil and filter. also checked the oil and it was not milky or foamy. i wonder sometimes if the **** ethanol they put in the gas now screws things up on these older engines. thanks for the input.
   / smoke out vent tube #19
If it is a gas tractor then it is very possible that the ethanol fuel absorbed water over the winter. The new fuels don't store nearly as well as the old gasoline. Best to make sure the tank is full (less air space inside the tank) and add a stabilizer to the fuel before putting away for the winter.
   / smoke out vent tube #20
One way to be sure is to take an oil analysis. Also sitting that long some antifreeze could have leaked in to the crankcase and it is evaporating. One thing I know for sure is that if you are getting a creamed coffee color gel like goo in the breather tube it is antifreeze.:thumbsup:
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2017 Chevrolet Express Box Van, VIN # 1GB0GRFF9H1305955 (A51572)
2017 Chevrolet...
Year: 2008 Make: Chevrolet Model: Suburban Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 219,... (A51694)
Year: 2008 Make...
2023 Dynapac cc900 Double Smooth Drum Roller (A51573)
2023 Dynapac cc900...
