Dirt Moving FEL on GC2400 for Digging?
   / FEL on GC2400 for Digging? #1
jmpbuffalo
Member
Western New York
Massey Ferguson GC 2400
Hi, folks,
Not sure if I should place this here or in "buying/pricing" but here goes. Can the FEL that goes with the GC2400 be used for digging? For instance, if I wanted to scrape away topsoil down to a depth of 6 to 12 inches for a path, or just for grading? If so, does anyone have experience comparing it to the Kubota 2320 with the LA304 FEL?
Thanks,
Joe
   / FEL on GC2400 for Digging? #2
No way is a little 2400 is not going to be effective, digging with the FEL.
Loosen it up with a plow first, and then you will have no trouble removing it with the 2400 FEL.
   / FEL on GC2400 for Digging? #3
Although its not the proper tool/attachment for the job, it can be done.It will take more time an patience. a toothbar will also make it easier to do.
   / FEL on GC2400 for Digging? #4
it's very easy to underestimate those machines.:)
   / FEL on GC2400 for Digging? #5
I don't think the Kubota is going to do much different. You must loosen the soil first to remove it first.
   / FEL on GC2400 for Digging? #6
Short video and pic of what these small tractors are capable of.
85% of this was done ,using the loader.
YouTube - GC 2310
   / FEL on GC2400 for Digging? #7
You can do a lot of dirt work if equipped for the task the other end of the little Massey would need a box blade with rippers to loosen the soil and I would get a tooth bar. You can dig with a FEL but it is better to loosen it up a bit before scooping it up. I also do most of my earth work in the spring when the freeze thaw cycle has softened the ground for me.
   / FEL on GC2400 for Digging? #8
Depends on the type of soil you have. With light sandy soil it's easy. With heavier clay soil I'd break it up first. If rocky I wouldn't try it with a SCUT. IMHO
   / FEL on GC2400 for Digging? #9
All true.:thumbsup:
Thanks for all the replies. The video showed just the sort of thing I had in mind.
Joe
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
UNUSED FUTURE 10' SLIP ON FORK EXTENSIONS (A57193)
UNUSED FUTURE 10'...
Takeuchi TL12R2 (A53317)
Takeuchi TL12R2...
UNUSED JCT 72" HYD TILLER (A57193)
UNUSED JCT 72" HYD...
406 (A52706)
406 (A52706)
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
