Hi.
   / Hi. #1
PomBee
Massey Ferguson 135
Hi All,
I'm new here, and new to tractors. My wife and I just bought an MF135, but unfortunately it's just developed an electrical problem. It shorted to earth due to the lighting wiring dropping onto the hot exhaust manifold. I hope to get it sorted out quickly as we have a lot of work for it!!
Anyway, just wanted to say "Hi".
Cheers,
PomBee.:drink:
   / Hi. #2
Welcome to TBN!!
There is a Massey Ferguson forum and I do suggest you check it out. Might be some good info there for you.
Peruse the other forums too...since you're new to tractors, the Safety forum is always a good place to start.
Good luck on the electrical repair...
   / Hi.
Thanks, Roy. I'll definitely check out those forums.
Cheers,
PomBee.
   / Hi. #4
i take it is a gasser and now won't start.
check the wiring for evidence of a fuse in the supply side.. or if only the lamps.. check the switch.. many lamp switches are also fuse holders.
post back
soundguy
   / Hi. #5
Welcome to TBN again.. I think we may require pictures for you to post as a newbie.:D Of the tractor that is.. Or if you want of you and the Misses. Anyhow as mentioned be safe.
   / Hi. #6
You have my sympathy, we have a 1986 Massey Ferguson 375 that has had ongoing electrical problems. We don't even bother with trying to fix them anymore beyond just to the point to where it will run, no instruments or lights.
   / Hi.
post back
soundguy
Hi Soundguy,
Yes, it's a gasser, but the electrical problem is that it developed a dead-short (the cabling for the headlights came loose, and dropped onto the exhaust manifold, melted, then shorted). I've decided to rewire the tractor completely as part of a quicky renovation. I'm just waiting for the rain to stop!!!
Cheers,
PomBee.:drink:
   / Hi.
Hi Treemonkey1000,
I'll take some photos of the Beastie once the heavens have stopped opening! My Wife and I are very proud of it, even if it is a bit on the tatty-side. We're going to treat it to a rebuild over the next year (slowly, but surely, I think), but it's going to have to earn it's keep. Not only are we new to tractors, we're also new to Nova Scotia as we are ex-pat Brits who decided to escape the rat-race. We survived our first winter here, so we think that we're ready for anything (hopefully). We'll update as we progress.
Cheers,
PomBee.:drink:
   / Hi.
Hi TripleR,
I know what you mean. Very few of the gauges, etc on our 135 are actually connected to anything. I'd like to sort the electrics out when I can, but if I can get it to start and run, I'll be happy with that!
Cheers,
PomBee.:drink:
   / Hi. #10
Cripes you moved to a cold in the winter bit of rock didn't you?. I here it is pretty there other parts of the year. It does rain on this coast a bit. It doesn't get bloody cold like out there. Have fun fixing up that new tractor. If you are going to put that much work into why not look into something newer or with less wear and tear?
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A54607)
2020 KENWORTH T680...
2014 Jacobsen AR3 Commercial Mower (A53421)
2014 Jacobsen AR3...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
2018 John Deere 325G (A47477)
2018 John Deere...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
