bad times driving a well
   / bad times driving a well
At our local hardware, the guy will re-cut the threads for a buck. You'll likely be able to salvage those pipe pieces.
That's not a bad idea, if it's cheaper than buying more pipes. I'm not sure if our local place can do it or not but I will at least ask.
By the way, thanks everybody for the tips and ideas. I have limited "large heavy objects" at my disposal but I'm brainstorming this morning to see what I can come up with...
Amazon.com: well drive cap - Tools & Home Improvement
It looks like there are several brands of caps out there.
Yes, and it looks like I picked a bad one! I'm going to use BP's idea of just using the coupling and a washer on top of that. The couplings I have thread all the way down onto the pipe and I feel a lot better about that. I'm off to the hardware store, thanks guys for your help and I'll report back later, success or not.
   / bad times driving a well #14
I bought my pipe and couplings at Mills Fleet Farm.....but I have read where others say to buy this stuff from USA sources. Mine worked out.
I used a short (6") peice of "sacrificial pipe" to drive on. This short peice became destroyed by the time my well was driven. As said....keep tightening the couplings with a pair of large pipe wrenches.
To me.....the most important peice of gear when driving a well is an ELECTRIC JACK HAMMER. :thumbsup:
Ok guys, it's been a long day and thankfully it has ended on a much better note than it started on! I took my mangled pipes to a local plumbing shop and they put some new threads on for me which saved me about $40. I combined zz and bp's advice and came up with a fairly good solution. I took my T-post driver and welded an 8lb chunk of angle on the side of it, then welded a 3/4 x 4" bolt on the end so I could put another 20lb of cast iron weights on it so the device now weighs roughly 50lbs. I would add more if a machine was doing the lifting instead of me!
I decided to just use the couplings instead of trying to find another drive cap. After a few minutes worth of work, I stop and re-tighten the pipes and couplings. I drove in 5' of pipe with no problems in about an hour and it didn't damage the couplings or the pipe.
This method is pretty much what zz and others described except mine is lighter in weight and I have to "run" it manually (which is one good workout if you are in to that kind of thing). Even so, when I raise and release my driver, it strikes the pipe squarely and it has a much more positive feel to it. I lift it about the length of the driver and then let it fall, probably 18" or 2 feet at the most.
I'll post a picture of my contraption tomorrow but I just wanted to share the positive results of the advice I was given here earlier today.
Foggy, I remembered seeing one of your posts on this subject. I asked my local tool rental to see if they had a bit for their jackhammer for driving pipes and they looked at me like I was insane. After I explained it they understood and said it makes sense, but that they had never seen what I was describing.
   / bad times driving a well #17
You can rent an electric jackhammer for about $45. I think that would be well worth it. They can set you up with the fittings for driving the pipe.
I can rent the jackhammer but they don't have the fittings for driving a pipe...like I said, they had never heard of it before and didn't have the fitting...
I could make one I suppose.
I hit water at about 13 feet and drove it in another 5 feet. Hooked up my pitcher pump, and after dumping some water into the top of the pump to get the seals working, got water. After a few minutes it was running clear!
I've built buildings and done all sorts of cool things but this ranks as one of my favorite projects. It will be worth the severe cramps I'm probably going to get in my arms later this evening!
Now I have to trench in 300' of wire for power...
   / bad times driving a well #20
Or else you could use one of these... We just put this up tonight under the light of the pending full moon (well a few hours before darkness).
Now where's that pesky railroad tie....
2019 GALYEAN...
2015 Peterbilt 320 Trash Truck (A55973)
2015 Peterbilt 320...
294 (A52706)
294 (A52706)
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
MURRAY PUSH MOWER (A55745)
MURRAY PUSH MOWER...
2000 FREIGHTLINER CLASSIC (A58214)
2000 FREIGHTLINER...
