WANTED: Restored 1953 Ford Golden Jubilee Tractor
   / WANTED: Restored 1953 Ford Golden Jubilee Tractor #11
i'll put my ear to the ground. I've seen several naa go under 2000$ lately.
you always have the option of buying one like that and sinking in 40-100 hours of time and another 1000$ and having a semi restored one. that's what I do :)
seriously.. I'll look around for you.
I know a guy in talahassee , member of an antique engine club I'm in )that has a nice one thart was thinking of selling in the 4000$ range a while back. have to see if he still has it.
soundguy
soundguy
Thanks Much !!!!!!:D
   / WANTED: Restored 1953 Ford Golden Jubilee Tractor #13
here's a decent looker in newport richie not much to make that one parade ready. probably offer 2100$ and setle for 2350.. but I'd probably pay 2500 if it ran good..
Ford Jubilee Tractor
trenton, this one likely needs about 150$ of tune up parts and oily stuff, and I'd guess about 40 hours of body work, another 200-300$ worth of paint, primer, thinner, masking tape, surfacing discs and sand paper and add in another 200$ for unseen misc items you might want to replace... this doesn't include any big parts. kick 150$ more in for battery and wire harness probablyand she's look pretty good. assuming she runs ok as is with no major worts. heck.. at that price.. if you don't get her.. I MAY. that's the right price range.. you likely can get her parade ready for total investment of 2500$ or less plus some skint knuckles, cussing and alot of late nights and sweat. I'd offer 1200 and settle for 1350..
palm bay.. wow.. cheap.. sat 5ys.. no biggie.. I parked my naa for 8ys while I played withother tractors. cleane dtrhe points charged the battery, changed the oil, put atf in the yls, pumped it out with starter, turned gas on.. put new plugs in and she fired on first crank.. this one might too. figure same overall effort and cost as the one abocve. both have good looking tins.. and tins are alot of the work.. ps.. I bet you offer him 700 and get it for 800 or 850..
FORD JUBILEE
now.. all that said.. here's some stuff to think about.
the average tractor owner don't know the difference between a NAA and a jubilee.. the aniversery year ( 50ys ) for ford.. the first NAA, ie.. the 53 year models were called the jubilee.. had a deififerent nose emblem.. and a few other differences. early jubes had the sn on the blok.. later ones on the trans bellhousing.. early ones had a bushing vs bearing in the clutch.. etc. minutia mostly... so check sn's if you are dead set on a 53
Year Starting Serial Number
1952 1
1953 2380
1954 77475
Also.. do you really want a jube or do you just like the looks of them. if just the looks, I'd look at the 55-64 machines instead of the 53/54.. better hyds on the 00/01 series.. and a few other minor improvement.s More trans options includinglive pto via 2 stage clutch ( *6* models ).. and the possibility of factory power steering.
good luck.. that's just what I found poking around. post back some thoughts.
as far as labor goes.. if that 1st one ran good.. I'd tap that one and then add the sprucing up to it to finish it off.. if you are looking for least elbow work..
soundguy
   / WANTED: Restored 1953 Ford Golden Jubilee Tractor #14
any of those pan out?
soundguy
   / WANTED: Restored 1953 Ford Golden Jubilee Tractor #15
Big Mike
I have just what you are looking for. I have a original completely
restored 1953 Golden Jubilee tractor. I am located in Winston Salem
NC the tractor is local to here. Asking price $7700.00, email
lawson.d@att.net, Phone 336-413-4253. Contact if interested.
Thanks
David
   / WANTED: Restored 1953 Ford Golden Jubilee Tractor #16
wowzers!
   / WANTED: Restored 1953 Ford Golden Jubilee Tractor #17
I wish I had seen this yesterday, as I had a friend bidding on a machine on ebay, and he finally dropped out because of his expense of going after it. I probably could have picked up a tractor and his machine and brought them both to Florida, since I had offered to go after it if he won it, for expenses. Splitting the expenses with two buyers might have allowed my friend to continue bidding just a little bit higher.
Oh well, hindsight is 20/20....
David from jax
   / WANTED: Restored 1953 Ford Golden Jubilee Tractor #18
i've been seeing naa go in the 1xxx and low 2xxx $'s here lately. deffinately a buyers market in and around florida for 4 cyl fords pre 1965.
soundguy
   / WANTED: Restored 1953 Ford Golden Jubilee Tractor #19
What is an naa?
   / WANTED: Restored 1953 Ford Golden Jubilee Tractor #20
It's the model of tractor that ford made after the 8n in 52, but before the 00 series in late 54.
The 'jubilee' designation is just that.. a name for a 50th year aniversery NAA.
A handfull of NAA were made in late 52, then the bulk in 53, then the ballance in early to mid 54. The 53 year model ones are called Jubilee's. Ironically as far as rarity goes.. there are more 53 NAA (jubes) than there are 52 and 54, thus the 54/52 naa are technically more rare .. yet all you see is people collecting the 'jube' models.. :)
soundguy
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
2014 Dodge 5500 4X4 Bucket Truck (A55302)
2014 Dodge 5500...
2013 Ford Edge Limited AWD SUV (A55853)
2013 Ford Edge...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
