trailer tire pressure
   / trailer tire pressure #11
Here's a PDF from Carlisle. At the end there's a chart showing how much weight a tire can handle at a given pressure. They say always inflate the tire to the maximum pressure but like I said earlier I don't like keeping trailer tires inflated that high. I could be wrong but I think the extra force of the pressure in the tire while sitting is not a good thing (unless trailer is loaded).
http://www.carlisletire.com/product_care/trailer_tire_service_guide.pdf
   / trailer tire pressure #12
Keep a eye on the pressure. I run max pressure all the time on my trailers.
Chris
   / trailer tire pressure #15
Running max pressure makes since to carry max load but there are plenty of times I run empty long distance to pick up something and have worn center of tires out rather quickly.
I tend to go by contact patch for empty and then air up to Max after I load and tires have cooled off.
   / trailer tire pressure #16
Its been my experience that when a truck tire is going flat it will give you enough warning to get off the road and time to fix it before irreversible damage is done. On tandem axle trailers the only clue I have ever gotten is what I can see in my rear view mirror. I keep a lot closer eye on my trailer tires than I do my truck tires.
   / trailer tire pressure #17
I actually feel them most of the time. Last two Goodyears on my 3 year old boat trailer both lost the tread but I felt it a few miles before.
Chris
   / trailer tire pressure #18
Chris
How do you lose a tread on a trailer tire? Were these recaps?
   / trailer tire pressure #19
I pulled trailers to make a living for over 11 years. One thing I've found is the tire on a trailer last longer with max pressures. Watch a tire on a trailer as it slides sideways (side scrubbing) going around a cornor. The tire with max pressure will hold its shape better to protect its internal belts and protects against sidewall cuts and bruises from the rim while rolling over a curb or pothole/etc.
Goodyear says this:
Goodyear max tire pressures
Special Considerations
Unless trying to resolve poor ride quality problems with an RV trailer, it is recommended that trailer tires be inflated to the pressure indicated on the sidewall of the tire. Trailer tires experience significant lateral (side-to-side) loads due to vehicle sway from uneven roads or passing vehicles. Using the inflation pressure engraved on the sidewall will provide optimum load carrying capacity and minimize heat build-up.
Carlisle also says: (snip)
However; trailer weight does not fluctuate sig-nificantly with variances in fresh and waste water and supplies, and trailer owners should always inflate to the maximum pressure listed on the tire sidewall. The inflation figures are for cold tires; if you check pressure after the tire has been driven and thus warmed, you'll find it higher. This pressure rise is normal and accounted for in the maximum cold-pressure rat-ing.
   / trailer tire pressure #20
No, new tires with a build date of 2006. Just junk. I have had it happen before on a set of Junk Carlisle's also back in 2004 on a brand new boat trailer I had less than 1 year. On that instance it was on a tri-axle trailer. In a 800 mile trip we lost 3 tires, only one lost the tread. Made it home on 3 used car tires, Sunday and that was all I could get. I went the very next day to get all new Greenball Towmasters put in it and wanted to keep the other 3. The tire guy called me and said they had bubbles on the inside of the tires opposite of the tread.
Just this year, in May some time, I had a Goodyear Marathon let go on a Repo Boat I took in. The one I was talking about in my original post. 2006 build date on a 2007 trailer. It started shaking the truck like crazy. Pulled over and there was a broken cord and a chunk of tread about the size of a candy bar missing.
Chris
2022 Morbark Eeger Beever 1215 Towable Brush Chipper (A56857)
2022 Morbark Eeger...
2012 John Deere 6170R (A57148)
2012 John Deere...
2011 SHOP MADE DUETZ MARATHON 60KW GENERATOR TRAILER (A58216)
2011 SHOP MADE...
Toro Timecutter Max (A57453)
Toro Timecutter...
IRanch Mini Excavator Wood Grapple (A57149)
IRanch Mini...
JOHN DEERE 333G SKID STEER (A52709)
JOHN DEERE 333G...
