New Kubota L4240/L4740 vs slightly used JD 4520
   / New Kubota L4240/L4740 vs slightly used JD 4520 #1
canoetrpr
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
I am about ready to pull the trigger on a cabbed 2007 JD 4520 eHydro with 120 some hours. It is in absolute mint condition. I was planning on going over this weekend to give the owner a deposit to hold until I can free up the cash to get it picked up.
The JD comes with:
  • 400x loader with JD QA bucket and bracket
    Radio
    Various extra mirrors and worklights
    Air suspension seat from what I can tell - it is dang comfortable.
    One rear remote
    iMatch
    R4s
The total price is $35500 with no tax as it is a private deal. New machine price for this around here is about $43-45000 + 13% tax so it i has been down the depreciation curve already which is nice.
When I started pricing out the things I wanted to get done and a little bit of the hassle involved in getting them sourced, they started to add up:
- Two extra outlets at the rear ~$2500 installed with taxes in.
- $750 to 1000 to transport it here as it is 2.5 hrs away.
- Purchase of SSQA adapter and conversion of bucket to SSQA (I have forks and a hay spear that are SSQA) - $800 to $1000
- Loading tires ~$500 for Calcium
Total: $40500
If I compare that to a new Kubota L4240 (10 less HP)
- Cab
- No radio (I don't really think I need it to be honest - I like the quiet time)
- 2 rear remotes - sufficient - one for the top link and another for snowblower chute rotator.
- No delivery charge.
- Already has SSQA
- Loaded R4s
Total: $37604 + 13% = 42492.52. Speeco QH or Pats can be added to take the price up to $42800.
I'll have to dig in to worklights and mirrors but I am sure they can be negotiated in.
A L4740 is close in HP that would be another $2000 I think so $44500.
The JD is a much better deal having been through the depreciation curve already. I could purchase it and sell it 3 years down the road with a couple hundred more hours for not much less. I don't plan on selling either but then I didn't plan on upgrading from my current L3400 either 6 years ago when I bought it.
I think both the JD and even the L4240 will do everything I need - 6ft bush hog, blower - same sized implements really. I don't have an implement wanting for the extra HP.
The JD's cab sticks out as spectacular to me and much more comfortable than the Kubotas. My Kubota dealer does not have a L4240 or L4740 yet for me to drive but a L4740 is on is way.
Both will require me to spend on a hydraulic top link and a toothbar so those are moot.
I'd appreciate your thoughts. I am leaning towards the JD for the value and the cab. I sure like the idea of not having to source stuff for the tractor, convert the bucket etc. Kubota dealer might even take my current tractor in a trade at a reasonable price making it easier.
   / New Kubota L4240/L4740 vs slightly used JD 4520 #2
I'm generally an orange kind of guy, but it would be hard to pass up that 4520, and it is one beautiful tractor, without a doubt. About the only thing I can think of that might make a difference is if you really got hooked on the HST+ over the eHydro. Such a choice! Oi vay!
   / New Kubota L4240/L4740 vs slightly used JD 4520 #3
Both tractors are good machines. You'll take more of a hit with the Kubota because of the initial depreciation. I'd take the 4520 but I already have a Deere and am looking at getting a 4520 as I downsize.
   / New Kubota L4240/L4740 vs slightly used JD 4520 #4
Most of my tractors are orange, but I couldn't pass up on the JD4520.
I must be missing something as you say it has loaded tires, but list $500 to put calcium.
   / New Kubota L4240/L4740 vs slightly used JD 4520 #5
This might be a personal quirk, but I'll take new over used anytime... Unless, PERHAPS, the used from from a family member and I knew the entire history of the machine intimately ..
As always .. YMMV
My mistake. The JD4520 tires are NOT loaded. I will have to get them loaded.
   / New Kubota L4240/L4740 vs slightly used JD 4520 #7
Most on here load with Rimguard or windshield wiper fluid in lieu of calcium due to corrosion. Rimguard is pretty expensive stuff; don't know the cost of WWF, but we have it in our tractors.
   / New Kubota L4240/L4740 vs slightly used JD 4520 #8
I'd go for the new Kubota! :thumbsup:
2007 is an old machine... it's almost 2012! :laughing:
Plus I trust Kubota more than I do Deere in this horsepower range. :cool:
Good luck!
Curious to know where you guys are able to source all that WWF from? Does it come in a big drum that I can transport on a pallet in the pickup? That would be useful as I could keep the drum around in the case of a leak.
Also how much difference is there in weight per gallon vs. Calcium and RimGuard? Not that it should matter that much because I generally do have something hooked to the back of the tractor. There is the odd time when I lift something that I don't have anything hooked to the 3pt.
   / New Kubota L4240/L4740 vs slightly used JD 4520 #10
My dealer only uses WWF, so that is where I got it; don't know where else it can be obtained. Someone posted the various weights, but I don't know the name of the thread though I do know Rimguard is the heaviest.
Hopefully someone more knowledgeable will happen along.
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2017 FREIGHTLINER...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
2020 Chevrolet Silverado 3500 HD 4X4 Service Truck (A52377)
2020 Chevrolet...
New/Unused AGT Industrial LRT23 Mini Skid Steer Loader (A51573)
New/Unused AGT...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
