WHAT IS THE USE OF HYDRAULIC OIL IN EXCAVATORS?
   / WHAT IS THE USE OF HYDRAULIC OIL IN EXCAVATORS? #1
nin88rab
hyundai550-3
WHAT IS THE USE OF HYDRAULIC OIL IN EXCAVATORS? HELP...
   / WHAT IS THE USE OF HYDRAULIC OIL IN EXCAVATORS? #2
Ummm.... To operate the hydraulic pistons.... extend and retract the arm and curl the bucket.
   / WHAT IS THE USE OF HYDRAULIC OIL IN EXCAVATORS? #3
it makes it move
   / WHAT IS THE USE OF HYDRAULIC OIL IN EXCAVATORS? #4
All the motor does is run the hydraulic pumps. The hydraulics do all the actual work and movements.
MarkV
   / WHAT IS THE USE OF HYDRAULIC OIL IN EXCAVATORS? #5
Surely you jest.
But in case you don't know, it is the fluid used in hydraulic systems to operate the cyl, motors, in a hydraulic system.
The flow of the hydraulic fluid is accomplished by a hydraulic pump, and hydraulic valves direct the fluid to certain places to operate the hydraulic cylinders and hydraulic motors.
A gas or diesel engine will power the hydraulic pump.
   / WHAT IS THE USE OF HYDRAULIC OIL IN EXCAVATORS? #6
Perhaps he meant to ask what hydraulic fluid is used in excavators? That would make more sense to me. The OP needs to clarify, please.
   / WHAT IS THE USE OF HYDRAULIC OIL IN EXCAVATORS? #7
I think Jinman hit it on the head. Maybe the persons english is a second language? If that was the question, what kind of hydrulic fluid should an excavator use? The answer would be what the machine specs in the owners manual. If you don't have the owners manual, I would think any standard hydrualic fluid would work.
   / WHAT IS THE USE OF HYDRAULIC OIL IN EXCAVATORS? #8
At least they didn't call it hydrolic oil. That comes in a wheel barrel.
   / WHAT IS THE USE OF HYDRAULIC OIL IN EXCAVATORS? #9
oil is used for hydraulics since it doesnt compress like air or water does.
   / WHAT IS THE USE OF HYDRAULIC OIL IN EXCAVATORS? #10
Water is just as incompressible as oil. But, water does not lubricate and causes rust.
2013 BMW 328i Sedan (A56859)
2013 BMW 328i...
1760 (A58375)
1760 (A58375)
John Deere 515 Grain Drill (A59225)
John Deere 515...
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
2018 John Deere Z997R (A53317)
2018 John Deere...
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
