Sprayer chemical mixing
   / Sprayer chemical mixing #1
kaferhaus
Mobile, Alabama
Kubota BX24
Ok I'm new to the sprayer usage as pertains to large tanks...how are you mixing the chemicals? If you add chemicals first you get foam that's ridiculous...takes forever to fill the tank. If you add the chemicals after the water how can they possibly be mixed correctly? There's no way to agitate the mix to insure proper blending that I can see.
Enlighten me please.
   / Sprayer chemical mixing #2
What I do is...
1) add water so there will be enough "water movement" after chemical is added
2) add chemical
3) drive the tank to, or around the area to be used (which is probably rough enough to mix) and it is generally mixed as good as if you had an agitator.
   / Sprayer chemical mixing #3
I have a separate line coming from the pump with a shutoff valve that allows me to circulate the tank. It would surprise you how little it takes to mix the tank. Add some food coloring when you add the chemicals. That would give you an idea of how well mixed it is.
   / Sprayer chemical mixing #4
Every commercially available sprayer I've ever had experience with has a built in agitator function.....It's the return line from the bypass side of the regulator.
I ALWAYS put water in tank, THEN mix in chemicals, ALONG WITH anti-foaming agent, then start up the pump, run pto @ 540rpm with regulator set to 0 psi. In a matter of a few minutes, the agitator has mixed tank quite well....
   / Sprayer chemical mixing #5
The spray rig I have has a mechanical agitator in the tank, driven by a jackshaft off the pump.
   / Sprayer chemical mixing #6
Me too. But, do those little Disney electric tank sprayers have a return line? I am not sure if they do. Perhaps that is what he has, and that is his problem?
   / Sprayer chemical mixing #7
Well he does say large tank ... I can only assume he does have the agitation ability ... my tank has a plastic pipe inside the tank about 6" tall on the return side for that purpose.
As stated add the needed water, I then get it circulating thru the agiatator while I pour in the chemical. Mixes well.
This week I used for the first time water soluable fertilize ... thats a new mixing experience!!!
farmswithjunk ... at 0 PSI I don't get any agitation ??? I have to have at least 15 psi to get things circulating.
   / Sprayer chemical mixing #8
Hmmm. My sprayers bypass ALL flow from the pump to the agitator @ 0 psi.
Well I'm stupid as it gets.... upon further inspection my pump does have a bypass line. Guess that's what that "other" valve is for....LOL:ashamed:
2015 GMC Acadia SLT1 SUV (A50324)
2015 GMC Acadia...
2007 DEUTZ D 2011L03 MOTOR (A52472)
2007 DEUTZ D...
Bush Hog 2820 (A50120)
Generac Generator (A50774)
Generac Generator...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
2008 Bobcat LT313 Skidloader Trencher (A50774)
2008 Bobcat LT313...
