anybody add a rear 3pt hitch lever?
   / anybody add a rear 3pt hitch lever? #1
stub
Indiana
Kubota L3940HST, Kubota 7510HST (traded)
When I looked at Kiotis, they had a rear lever for the 3pt control, so you could reach it while standing at the back of the tractor.
Anybody been able to fugure out how to add that to a Kubota Grand-L?
   / anybody add a rear 3pt hitch lever? #2
About the second valve for rear implement hitch;
I dont think the second valve would play nice with the
radial piston or gear pump on the Kubota tractor as it
is a closed hydraulic system within the rear end and
the transmission.
You would need the hydraulic schematic to see if
it is even a remote possibility. Please forgive the pun.
_____________________________________________________________________________
Once you go flail you never go back:thumbsup::licking::drool:
   / anybody add a rear 3pt hitch lever? #3
I think it would be a good idea. Hmmm, a new project. I think you could just tie in to the existing lever with a rod to the back. Add a second lever and walla. It would make hooking up a three point implement easier.
   / anybody add a rear 3pt hitch lever? #4
It has been done and I've seen a picture, I think here on TBN, but I can't find the thread. I plan on adding it to my tractor.
   / anybody add a rear 3pt hitch lever? #5
My Kioti does, in fact, connect to the existing 3 pt height lever mechanically. And you're right, it does make it so easy to hook something like a disc hay cutter, which can be so frustrating that people pay $3500 for a dolly for them, often just to make it easier to hook up.
I also have a Montana, which I'd like to mod up the same, as well as find some telescoping lift arms, and the easy adjusting lower link stabilizers that the Kioti has.
   / anybody add a rear 3pt hitch lever? #6
Project Done. A piece of 3/16x1 steel, a 1/4x3/8x1/2 bushing, a hitch pin clip, a 1/4 steel dowel, and a 1/4 nut and bolt. Took more time to do the pictures than the rear three point lever.
   / anybody add a rear 3pt hitch lever? #8
I got 1 almost done for the Grand L series. Will post pics soon as the rain stops.
   / anybody add a rear 3pt hitch lever? #9
This is the ones I put on right after I got my L4240. Lost the use of the so called tool box, but wasn't using anyway.
lookin good. keep those pics coming. thanks
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2021 Ford F-250 (A55973)
2021 Ford F-250...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52707)
(INOP) 2016...
2015 Jeep Cherokee Latitude SUV (A55758)
2015 Jeep Cherokee...
