Diesel in a lawnmower?
   / Diesel in a lawnmower? #11
As long as you are talking 4 stroke engine you will be fine. 2 Strokes turn inside out with diesel.
   / Diesel in a lawnmower? #12
Drain the tank and the carburetor bowl and add fresh gas. I wouldn't even replace the spark plug unless it looks really carboned up.
Years ago, small engines were made that were started on gasoline, then switched to diesel once the engine was hot, then switched back before shutoff. So, it is not really a harmful thing to run diesel in a simple gas engine.
Not exactly. You started them on gasoline (regular tetra-ethyl lead gasoline) warmed them up, closed the carburetor shutter (that concentrated exhaust manifold heat on the carburetor), closed the radiator shutters (kept the coolant hotter) and switched from the gasoline tank to the distillate tank. Not diesel fuel, kerosene.
Even then, half went out the exhaust pipe.
   / Diesel in a lawnmower? #13
yep.. a vaporising carb really helped. but it made less power overall.. was cheaper though.
I'm sure ( tractor vaporizing oil ) tvo/distilate/kerosene/diesel/mineral spirits or even lamp parifin oil would burn in them.. as long as you switched back to gas at the ned to clean out the lines so she's start in the morning.. :)
   / Diesel in a lawnmower? #15
Thanks for the history lesson. I admit that I have only heard about it, never actually ran one.
   / Diesel in a lawnmower? #16
How is diesel going to do any physical damage to a two cycle engine.:confused:
On a different subject I have found by accident that our 18 HP B&S and 6.5 HP China knock-off Honda generators when hot and under full manual choke will keep running if switched over to pure Sea Foam.
As the adding gas to diesel mentioned above I have read years ago some MB owners would mix a small amount of gas in the diesel for better winter starting.
   / Diesel in a lawnmower? #17
My first real tractor was a 1941 International Farmall A dual fuel. Put an L59 Woods Belly Mower on it and mowed a lot of lawns,
That was back when gas was 30 cents a gallon.
Gawd, I'm gett'in old.:(
   / Diesel in a lawnmower? #18
Giving my age away....Chris...
My '41 Farmall had a Marvel Scheibler (think that's right) updraft and 2 fuel tanks. A small tank for gas and a large for kerosene/lamp oil, crank down shutters for the radiator and a hinged cover for the carb. It was such a PITA that I just used the big tank for gasoline. You had to run with the wind because half the distillate came out the exhaust pipe.
Learned about Fairbanks Morse Impulse Magneto's the hard way on that tractor. never hold a mag in your right hand and flip the impulse with your left....:D
   / Diesel in a lawnmower? #19
the 48 farmall C i'm working on has them nice shutters and the distilate manifold with the lever. battery ignition though.. :)
soundguy
   / Diesel in a lawnmower? #20
soundguy
Should work well for you in Fla with the skeeters on distillate. The sooty fog that eminates from the exhaust stack will keep all but the most voracious skeeters of your body as it gets coated from the oily exhaust......:thumbsup:
I still have the single bottom pull plow and the rockshaft assembly in the barn. The plow has never seen soil. Still has the cosmoline on the shareand moldboard.
I sold the tractor to a guy who wanted it to mow with and didn't want the plow or rockshaft. I've lost track of the tractor but I imagine it's somewhere restored, doing shows. The old wide front offset A's are real collectable up here now.
I think I have the original owners manual and bill of sale somewhere too. Probably should put that on Flea-Bay.
The mag was a PITA. Should have converted it to battery and coil and a single wire alternator but never did.
UNUSED FUTURE CW59 59" HYD COMPACTION WHEEL (A57193)
UNUSED FUTURE CW59...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
LaneShark LS3 (A56469)
UNUSED FUTURE FT-HJ6 40' METAL STORAGE SHELVES (A57193)
UNUSED FUTURE...
2018 BOBCAT E50 EXCAVATOR (A52707)
2018 BOBCAT E50...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
