Tractors with 84" MMM on a compact?
   / Tractors with 84" MMM on a compact? #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
Who makes the biggest (I'm presuming 84") MMM/cab/4WD/compact?
I have found a CASE-IH with an 84" MMM. I think NH still makes their compacts with the 914 84" MMM, but dealer told me they may be dropping them because someone new is building their compacts.
Anyone else make a cab/4WD compact with a 84" MMM other than Case IH or NH?
   / Tractors with 84" MMM on a compact? #2
Kubota makes a cab/mmm but i believe you can only get up to a 72". John Deere makes them also but not sure if you can get the 84".
With a 84" mower i'd be worried about it scalping the ground unless it is perfectly smooth.
   / Tractors with 84" MMM on a compact? #3
I agree here, 84" is a wide mower. I don't know of any companies that make one but I would stay clear of something that large on a MMM. Rear mower with the tires is a different story. I would go with a 72".
   / Tractors with 84" MMM on a compact? #4
I just cant figure out what a MMM is please show a picture? "middle mount mower"/?
   / Tractors with 84" MMM on a compact? #5
Mid-Mount-Mower
The mower underneath the tractor is a mid mount mower and the one behind is a rear/3ph (3 point hitch) mower.
   / Tractors with 84" MMM on a compact? #8
Wether they sell it and its usable is different though. If the land is extremely flat it would work but 84" is not going to handle little slopes well and give a very uneven cut. Also don't think you would get a very good cut as that is a lot of mower for a mid pto.
Maybe, but not as bad as my 90" rear finish mower I'm using now. 72" MM mowers are very common. 84" is only 6" bigger on each side.
Why would a mid PTO have any less power for an 84" mower than a rear PTO for an 84" mower?
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
PALLET OF SCAFFOLDING (APPROX. 12 PC) (A52706)
PALLET OF...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
