How do you sharpen your tungsten?
   / How do you sharpen your tungsten? #1
jake98
Dingmans Ferry PA
53 Cub, 70's JD 410, Kioti 25hst
Can you use a handheld grinder with a diamond wheel, or do you have to spend hundreds on a dedicated tool? Stationary grinder?
   / How do you sharpen your tungsten? #2
At work we use a sanding belt. If we are tigging stainless we make sure the belt isn't contaminated with carbon steel that would cause rust in the weld.
   / How do you sharpen your tungsten? #3
No, you don't need a diamond wheel or dedicated tool, use whatever you have on hand. Always try to grind with the tungsten oriented vertically to the wheel's direction of rotation.
   / How do you sharpen your tungsten? #4
I use a dedicated wheel on a bench grinder. I never have been much of a Tig weldor but I can get by. So I don't see the need for a $300.00 tungsten grinder.
One of the best Tig weldors I've ever met, Engloid you can do a search for his name on any of the welding sites, the guy is amazing! He is of the same mind set.
I had myself in a little panic right before I posted that, "tell me I don't have to spend another $300..". After reading for about an hour on some other sites I see there's quite a few ways to grind them, that I already have. I like the diamond blade on the side of the grinder stone trick, that only takes another 1/16" of shop space. But here's another ?, do you have to worry about contamination when you're welding mild steel? or is it just on stainless, alum, etc.? (for shop repair stuff, I'm not trying to pass any tests)
   / How do you sharpen your tungsten? #6
Bench grinder, tungsten only wheel.
There is a Pirhana at work that I can access too.
   / How do you sharpen your tungsten? #7
I just use my bench grinder with a dedicated wheel. The only thing extra I did was to purchase a fine grit wheel. The wheel was kind of pricey. I think I paid around $30.:thumbsup:
   / How do you sharpen your tungsten? #8
How about one of those little Dremel tools with a diamond wheel.
   / How do you sharpen your tungsten? #9
I recall hearing a way where you can sharpen them with a cutting torch. I wil have to look for that page again.
   / How do you sharpen your tungsten? #10
That's a bit on the small side even for 3/32 tung.
I've looked at the chemical sharpeners but a wheel is quick, easy and puts Thorium dust in the air.....lol
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
2018 John Deere TX Gator (A50123)
2018 John Deere TX...
2017 TOP HAT TRAILER 16 FOOT UTILITY TRAILER (A53843)
2017 TOP HAT...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
2007 Kubota L2800D 29HP Utility Tractor (A51691)
2007 Kubota L2800D...
2020 Chevrolet Express (A50123)
2020 Chevrolet...
