block heater on sc 2400??
   / block heater on sc 2400?? #1
dslanec
Northern Michigan
CUB/YANMAR SX 3100
Do i need to get a block heater for the tractor? I live in northern michigan and the tractor is already getting harder to start and the temp today was about 35. It is stored outside not in a garage. When it first starts it idles at about 500 rpm's for about 10 seconds untill it warms up enough to idle like normal. I dont want the first real cold weather and snow to come and my tractor wont start. Please let me know your thoughts.
   / block heater on sc 2400?? #2
Any engine that sits in the cold will benefit from a block heater. That's your baby, keep her warm! put it on a timer so you can have her hot when you want.
   / block heater on sc 2400?? #3
Northern Mi?? Outside?? Definitely a block heater. How about one of those little portable garages for around $300 to keep the snow and rain off?
Just a thought.....
ya i have been looking at those at tsc. they were on sale for $240.00 this past weekend. I did some research and found out they dont hold up real well in the wind. And i basically live in a wide open field and it gets very windy. Im currently looking for a cover but am having no luck. My only hope is that a john deere 2320 cover will fit? The dimensions are very close with the john deere a inch or 2 smaller in some areas but the bottom of the cover has a draw cord if it is slightly to big. Does anyone know if installing a block heater is simple or not? I called my local dealer and can get one for $82.00. They said it goes in place of a freeze plug. I will have to look at the tractor tonight and see how open the freeze plugs are.
   / block heater on sc 2400?? #5
I put one on my B7800 and it is simple if you have the right tool. Mine required a very large metric allen wrench. I made one out of a metric bolt and an old 1/2" socket rather than buy one for the one use. It worked well. :D
   / block heater on sc 2400?? #6
Those light weight, inexpensive shelters will collapse in a snow. There is a block heater for the 2400, as you know. There is also a lower radiator hose heater. You install it by removing the lower rad hose and putting the electric heater device inline with two shorter hoses. I'm looking for the block heater this year, and the lower rad hose heater for next year. No sense wasting all that new coolant.
Radiator heater part number 759-04003 from Cub or 1A7880-57250 from Yanmar.
This is all new to me. If I get the block heater and take out a freeze plug. Do I have to drain the coolant first?
   / block heater on sc 2400?? #8
Definitely or it will all run out the freeze plug hole. Same deal with the hose heater but it would be easier to install IMO.
Bob B.
   / block heater on sc 2400?? #9
You can also try this site.... Wolverine Engine Heaters
they sell, and i have purchased 3 of them, a glue on heater. they are super easy to install and dont have to drain anything.
And boy do they work great
I put on a 125 watt heater on the oil pan (needs a flat spot, no ridges), a 250 watt heater on the transmission/HST unit and another 250 watt heater on my 3 point reat hydraulic tank that supplies the snow blower.
I set mine to operate on a wall timer for a few hours before i need the tractor, and only use them if the temp is below 20F.
Without them everything growls and protests starting up (like i do climbing out of my warm bed) , but with them everything starts nice and smoothly....major difference.
Are these the freeze plugs?
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55218)
Kubota SVL65-2...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
Year: 2013 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 79843.5 Plate: Body Type: 4 (A53422)
Year: 2013 Make...
2017 Mitsubishi Outlander Sport SUV (A55758)
2017 Mitsubishi...
2015V Chevrolet Equinox SUV (A55758)
2015V Chevrolet...
2008 Ford F-550 4x4 Dump Truck with Lift Gate (A53422)
2008 Ford F-550...
