moldboard plow horsepower
   / moldboard plow horsepower #1
brcisna
Member
West Central Illinois
Mitsubishi MT2501D
Hello All,
New to the compact tractor world. Going to purchase a moldboard /breaking/turning,plow for my 25 hp pto, tractor,4WD and would like to hear others plowing experiences. Such as soil type,plow width,12",14",16",coulter,no coulter, 2WD,4WD,etc.
Thanks,
Barry
   / moldboard plow horsepower #2
with your tractor running in 4wd you can safely pull a 12 in 1 bottom plow.
   / moldboard plow horsepower #3
Coulter wheel in front of the plow is needed to cut the grass so it flips easily and also helps to stabilize the plow. Dont buy a used one without the coulter wheels and the tail wheel. I've seen lots for sale that have neither and I dont think they will work correctly without them. I havent used them in 50 years but my dad had what he called a Pan plow that had 2 deep cupped smooth disc blades about 20-24" in diameter that he pulled with an 8N in medium heavy loam soil. They cut as well or better than a moldboard and dont hang up on roots or rock like the moldboards do. I think they pull lots easier also. No coulter wheels needed on these either.
   / moldboard plow horsepower #4
A general rule of thumb is 1 HP for each inch of plow. So a 2-12 would need about 24 HP. You could pull a 1-16. A 2-12 would depend on soil condition with your tractor. Draft control is also important for maintaining plow depth. Plow should plow about half the width. Twelve inch moldboard 6 inches deep.
   / moldboard plow horsepower #5
Brinly sold 12" plows for John Deere 140 garden tractors which had 14hp engines and weight of about 700 lbs so a compact should handle a 12" no problem.
   / moldboard plow horsepower #6
brcisna, Have a look at the thread "What kind of plow should I get" On P13 at the time of posting. Last post by Chilly807 on10-27-2011. In particular follow through his posts and see the difference in his plough and some of the others photographed.
   / moldboard plow horsepower #7
I have heavy clay soil. My 37 engine HP Kubota did okay with one 16 but struggled with 2 x 14 and wouldn't make it at all on a tough area. I now have a 57 HP L5740 and this year it struggled with the 2 x 14. It was just a tough year, so not only the soil matters but also how the weather treats you. I think I could pull 3 x 14 at my brother-in-laws rich bottom land Missouri.
   / moldboard plow horsepower #8
A good plough does not need discs !
http://www.google.ca/url?sa=t&rct=j...0YTYDQ&usg=AFQjCNEIvxmt4vSsHW481RP5whf-2xAUEA
Not many of my ploughs have had discs !
Correctly set skimmers are far more important !
   / moldboard plow horsepower #9
Hello All,
Thanks,
Barry
25 hp pto probably means about 20 hp on the drawbar or 3pt hitch where you attach the plow to the tractor.
Be aware that the trend for decades had been away from moldboard plows since they produce hardpan (because the right wheels run in a furrow and compact the soil = hardpan which eventually causes drainage problems). Chisel plows and discs are preferred since they produce less of a hardpan problem.
With 4WD you probably can pull a lightweight 2-14 if the soil is fairly loose (e.g.gravely loam). Your little tractor would struggle if you tried to pull a 2-14 through soil with a lot of clay content. My JD 2-14 moldboard plow (3pt hitch type) is one heavy sucker and probably would be a real load for a 25-hp tractor.
The soil on my 6-acre hayfield is shallow, thin gravely loam so I don't dare flip it with a moldboard plow. That justs buries the good soil and leaves inferior soil on the surface of the field. I use a 6.5 ft offset disc for primary tillage and a 7-ft tandem disc for secondary tillage, both of which are over 50 years old.
Good luck
   / moldboard plow horsepower #10
Look at pics 2 and 3 of the reply by D7E. If your plow moldboards don't look like that you're wasting time and HP.
Horse power calculations are for plows that have a scoured / polished set of moldboards and not for some piece which set in fence row on the back forty that has rusted and pitted for the past 30 years.
2022 Freightliner M2 106 Medium Duty Rollback Truck, VIN # 1FVACXFC5NHNM7347 (A51572)
2022 Freightliner...
2020 UNVERFERTH 332 LOT NUMBER 199 (A53084)
2020 UNVERFERTH...
2008 Chevrolet Uplander LS Van (A51694)
2008 Chevrolet...
2018 JOHN DEERE 160G LC EXCAVATOR (A51246)
2018 JOHN DEERE...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
2000 Ford F-150 Pickup Truck, VIN # 1FTRX17W7YNA75070 (A51572)
2000 Ford F-150...
