Temporary Horse Pasture - Fencing advice please
   / Temporary Horse Pasture - Fencing advice please #81
35 years & no rot? No concrete then I assume...that's what kills any post eventually.
I don't think you will replicate that stat with the "new" treated posts....I think they just dip them in Green Tea:laughing:.
I'm not sure that concrete is a killer. Maybe if it's overdone. I've heard to make sure there is drainage at the bottom, not encased in concrete. I pulled up some posts that I had set in concrete 7-8 years ago. The concrete stuck to it but when I busted it off, the posts looked new. Of course that's not 35 years either. OTOH, I'm sure that I won't last 35 years anyway.
I agree that some of the pressure treating today is very poor, thank big brother. You will notice that some PT items are marked "not for ground contact"....:confused2:
I think you have to be a careful shopper and make sure that the posts are properly treated for the intended use. Probably a farm supply place will have better treated posts than a hardware store or Wallymart:(
Ken
   / Temporary Horse Pasture - Fencing advice please #82
i never concrete in line posts here.
I have occasionally done corner posts.. but not usually.
soundguy
Soundguy,
Thanks for the reminder. Corners!
I plan to use round 6' posts on the corners of the PERMENANT Fencing, and instead of concrete, I will do 45 degree braces (I think).
For the temp fence, I will use tent stakes and tiedowns on the electric corner posts.
David
   / Temporary Horse Pasture - Fencing advice please #84
on my temp fencing I think I used 6-8 x 8 and no crete ,i DID use H or angle braces. In real sandy soil where the posts want to lift under hi-ten wire tension, I will drive in 2 tpost at rear angle of post and use #10 brace wire and make a holding loop, adding a staple to the post.
all can be pulled / dug out easy.. is solid.. and no crete.
good luck
soundguy
   / Temporary Horse Pasture - Fencing advice please #85
Just the opposite for me. All my 4x4 post pretty much snapped like tooth picks back in the huge snow ans ice storms here in 2008/2009. Since then i have replaced all the 4x4 with treated 6x6, and ALL are in concrete 3' deep. I mounded the concrete so i dont worry about rotting. I had to remove all my old 4x4 posts, which were also concreted, and there was NO rot. They simply snapped due to tonnage weight of 120" of snow on them.
I went shopping today!
At the local hardare I bought 60 16 foot poplar fence boards, 38 1/2 rnd posts, a 12' gate, an 8" round post for the gate, and four 6-7" round posts for corners. They will deliver Thursday morningI believe.
At TSC I bought 22 fiberglass step-in posts, 1200' of electrobraid, a 9" auger, new teeth for my neighbor's 12" auger, a 3 mile solar battery/charger and misc stuff like grounding rod, etc.
I can't seem to scan it in landscape, it keep coming out sideways, but the attachment is the rough plan. Approx 296' of wooden 3 board with a 12' gate (308' of permanent fence) and approx 548' of Electro braid temporary fence.
Most of the grass will be inside this area, there will be a couple spots of grass outside the fence.
I hope to start working for real this weekend, maybe do some small stuff Thursday and Friday.
Who's coming to help? :D
Be well,
David
  • Pasture Plan 1.pdf
   / Temporary Horse Pasture - Fencing advice please #87
sounds like you got some fun ahead of you!
   / Temporary Horse Pasture - Fencing advice please #88
Be well,
David
From your drawing it looks like ALL you'll have is corner posts. I've never seen a fence ramble and wander so much. Looks like you have a unique landscape. I bet it's pretty.
It is (or will be) Pretty. If I could take an aerial photo it would make more sense.
Keep in mind this "TEMPORARY" fencing. The wood is "Permanent".
What I am trying to do is enclose the GRASS I currently have, but NOT enclose the areas full of freshly ground up trees and stumps, and the un-ground up stumps, etc.
This is really just the parts the loggers did not log, the ol over grown garden and a clearing around some old dying fruit trees, and where the Walnut trees were.
I am doing this to save on bill I keep paying to have our Horses boarded.
I want them HERE NOW, while I take until next summer (or longer) to finish getting the other 4 acres of pasture in.
I hope tha makes more sense.
Eventually the wood fence will run along the driveway and the fire/access road, and I will have electric fence inside the tree line. Then it will look MUCH more typical pasture, somewhat rectangular even.
I hope that helps.
Be well,
David
   / Temporary Horse Pasture - Fencing advice please #90
David, depending on what vegetation will be inside your fence besides pasture grass, you may want to check on what is considered poisonous to horses. I'm no expert, I always rely on my daughters who are. But I think walnut maybe poisonous to horses.
2016 TANKKO 130BBL VAC TRAILER (A52472)
2016 TANKKO 130BBL...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
