3ph post pounder
   / 3ph post pounder #1
pickeringchris
Gold Member
Anyone heard of a commercially made or home made "T post" pounder? I have seen the big post pounders online. I was thinking something small.
Cheers
   / 3ph post pounder #2
If you know someone that has a Shaver brand, thye make steel post holders, so as to drive them with one. Steel Post Holder for PD8 Each
Or, they make pneumatic ones, like Northern Hydraulics sells.http://www.northerntool.com/shop/tools/product_200398563_200398563?cm_mmc=Google-pla-_-Farm%20%2B%20Acreage-_-Fences%20%2B%20Gates-_-511001&ci_sku=511001&ci_gpa=pla&ci_kw={keyword}
Takes 2 CFM @ 80-100 psi.
   / 3ph post pounder #3
If you have a front loader and a helper you can just use the bucket to push the t-post in if you have any amount.
   / 3ph post pounder #4
Not 3pt but I have a hand held pneumatic t-post pounder. It works well. I just toss the small generator and compressor in the back of the RTV.
   / 3ph post pounder #5
Yep, I've pushed many a t-post in with the fel bucket and a helper. Fast and easy.
   / 3ph post pounder #6
One of the cheapest and quickest ways is to use an electric jackhammer powered by a generator........no fuss or strain (apart from lifting it to top of T post) just push the trigger and the weight of the hammer will drive the stake in.
The special cup to fit the hammer are not expensive. I prefer just the round cup to the ones with a T shape in them..............then you can also use them to drive steel poles etc.
   / 3ph post pounder #7
Then you are blessed with good ground :thumbsup: I've done it a few times when the ground is very soft and I'm lucky enough to miss any rocks. Other times, our ground is closer to concrete.
Ken
   / 3ph post pounder
Some really smart ideas here. I have seen the attachment for the jackhammer. Pretty hard to lift the jackhammer on top a 7' post. :)
My ground is soft with no rocks. I'm gonna try the loader and brave helper first. I only have 50 posts to do. Still, 50 is a lot for work with one of those 30lb pipe type pounders.
   / 3ph post pounder #9
Just take it slow and unless someone does something really stupid its very hard to get hurt in this process.
   / 3ph post pounder #10
As a suggestion, check out the SDS hammer drills and 1" bit you can get at Harbor Freight for about $69. It is one of their tools that works really well. You can pre drill a 1" hole in the ground to make tapping in the T post by hand much easier. I will say a 1" hole is too small if drilling in rock or extreemly hard ground and you need the longest 1" bit HF has, about 14" long. For driving T posts into rock, you would need an SDS Max and 1.75" drill bit - a much more expensive setup. However, you might try renting one from a rental company. The SDS Max and a 3' - 1.75" bit is what we use in our solid limestone ground here in central Texas.
If you want to use the electric jack hammer with a cup, it works well, stand on the trucks tail gate and hook the jack hammer to a receiver hitch deer hoist. Now you can tilt the T post into the cup and stand it up and jack hammer it right on in.
2016 KENWORTH T270 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T270...
230112 (A53422)
230112 (A53422)
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2020 BOBCAT T76 R SERIES SKID STEER (A52705)
2020 BOBCAT T76 R...
JOHN DEERE 333G SKID STEER (A52705)
JOHN DEERE 333G...
SCAN FOR HAULING AND FINANCING INFORMATION (A54756)
SCAN FOR HAULING...
