TRACKED M126X Kubota
   / TRACKED M126X Kubota #21
MartianTractorMan said:
You wouldn't have been looking at a 9RT series JD were you? They are much larger with only one track. 460HP to 560HP range. Or was it another one like the Kubota pictured?
It looked a little larger than the Kubota in this thread but not by much. We were on the interstate so didn't get a great look.
   / TRACKED M126X Kubota #22
New Holland has them too...
That does not look like a oem solution. Is that offered by New Holland, or is that in an aftermarket booth? There is an aftermarket company in Canada that will put tracks on everything from 4-wheelers, small tractors, mid-size trators, pick-up trucks, etc. Philip.
   / TRACKED M126X Kubota #23
Kubota don't make the ones on there tractors ether. There just factory installed.
   / TRACKED M126X Kubota #24
Okay, I'll play your game. Are those tracks installed at the factory by NH/Fiat? Philip.
   / TRACKED M126X Kubota #25
I'm not trying to play any games, its not like I'm the New Holland guy trying to pick a fight with team Orange. I'm just here to talk about tractors. And I doubt it seeing as how the manufacture's symbol is still on the track frame.
   / TRACKED M126X Kubota #26
I am just trying to be clear. The Kubota track is an oem solution with installation, warranty, and support from Kubota. I am sure Kubota worked very close with the track manufacturer to 'build in' a factory representable solution. This takes almost all risk off of the buyer if they purchase on oem factory part. I have put good non-oem parts on trucks, and it can be a problem with the dealership and manufacturer at times if a problem comes up. Philip.
   / TRACKED M126X Kubota #27
KYDan said:
I played around on the Kubota site and read the specification sheet on the 8540 crawler and it appears that the tracks are not interchangeable with tires. It did state the top speed was 13.2 mph. That's fast for a crawler.
The 8000T series Deeres will do 20 plus mph. I am sure the Challenger will go as fast.
   / TRACKED M126X Kubota #28
I wonder how fast the case stiger's on tracks can go? I've see a lot of them in the Mississippi delta.
John Deere's High Speed Dozer (HSD) will do 16 MPH as well.
   / TRACKED M126X Kubota #30
I'm impressed. My M9 in high range and high gear will do 22 mph at rated rpm.
Wanna drag???:laughing:
2019 KEESTRACK K6 SCALPING SCREENER (A51246)
2019 KEESTRACK K6...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
2008 Ford F-150 Ext. Cab Pickup Truck (A50323)
2008 Ford F-150...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
