Have You Burned Poplar ?
   / Have You Burned Poplar ? #11
FREE always burns good...
Army Grunt
Good Evenin Guys,
Thanks for all your input ! I just got one good trailer load and will go back for a few more. As Jimmy and others have said I will just mix it in with the good stuff and use it for getting the fire going again and for spring and fall use !
Some of the rounds are rather large but it does spit quite easily, and should provide some amount of heat anyway ! ;):)
Free is allways good ! :thumbsup:
   / Have You Burned Poplar ? #13
I burn poplar when it is available, dried, and rot-free. I use wood harvested from my place to heat with a wood furnace. Trees available in order of numbers are fir, birch, pine and poplar. In order of what I burn are pine, birch, fir and poplar, with pine + birch five times the amount of fir + poplar. The order is mainly due to harvesting when the trees are at or near the end of their life cycle.
I've attached a previous post's link to a useful chart from the book "Firewood and Your Chain Saw". It is interesting to see the heat values for different species.
http://www.tractorbynet.com/forums/...ucket-load-firewood-weight-firewoodweight.pdf
   / Have You Burned Poplar ? #14
There are basically 2 kinds of poplar being discussed here........In the north it is small in diameter and short lived........The southern tree, tulip poplar grows up to 3' in diameter and lives quite a long life............
We've got all kinds in the north, quaking aspen, big tooth aspen, tulip, cottonwood, you name it.
   / Have You Burned Poplar ? #16
Yes, I've burned Poplar to erase any and all evidence that I thoroughly screwed up a wood project.:laughing:
   / Have You Burned Poplar ? #17
I've heard it said that there is more creosote in poplar (like softwood) than there is in the traditional hardwoods.
   / Have You Burned Poplar ? #18
The Haymaker said:
I have a bunch of box alder I'll give you.
Army grunt between haymakers alder and my cottonwood you'll be able to burn free for a long time
   / Have You Burned Poplar ? #19
I have a wood burning neighbor who orders a load of popple ( aspen ) from me every year. He uses it fall and spring in his kitchen stove for those "I need a quick fire" times. I burn some too.
   / Have You Burned Poplar ? #20
Just be careful with it Scotty as it will burn hot and quickly. Typical type of fire that start the chimney a blaze.
Wayne
2001 Great Plains 3N-3010P-4875 Grain Drill (A50657)
2001 Great Plains...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
2014 RAM 5500 FLATBED TRUCK (A51222)
2014 RAM 5500...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
