Box blade rippers
   / Box blade rippers #1
jshwhite
Gold Member
Missouri
Kubota L4740, Massey 65, Case 580C
Does anyone know where I can find replacement box blade rippers with the notch in the back? I found some with center holes, but can't find any that are back notched. I've got 3 on mine that are bent pretty bad - from ripping stumps out :)
Also, how do I tell what quality they are? I'm not too familiar with types of steel, but I'd rather something more flexible than brittle. Someone here on tbn a few weeks ago was having problems with the rippers breaking. I don't want that - I'd much rather they bend. The ones I've got will take brutal treatment without damage and I want replacements like them.
Thanks!
   / Box blade rippers #2
Thanks!
I bought some from Agrisupply they had the best prices and have held up well.:thumbsup:
   / Box blade rippers
Thanks. That's a good price too. Problem is, those are front notched and I need rear notched :) Like on this box blade pic I just found.
Then again, maybe front notched would work - I could just drop the pin in the back instead of the front.
Any thoughts?
   / Box blade rippers #4
"Good" ripper shanks like what you would get with a Gannon run a little over $60 each with the tooth being another charge on top of that. Most people settle for less, including me. ;)
   / Box blade rippers #5
Yeah, I'd much rather bend or even break a shank over tearing up my BB.
   / Box blade rippers #6
Have you ever thought about straightening them, unless they are bent to bad. I bent 3 of them and straightened them out using my log-splitter and they turned out pretty well. It only took a few minutes.
   / Box blade rippers
Yes, that was my first thought when I bent one. I like the log splitter idea, but unfortunately don't have one. I put the ripper in a vise and got a large pipe wrench and cheater bar. I heated it almost to the melting point and had someone else hold the heat on it while I applied pressure, but only succeeded in breaking my vise :( Called Wilton Vise and they said "Sorry, the lifetime warranty does not apply to movable parts." Hmm... thanks a lot. The vise is cast, so I welded it with nickel rod - worked great till I put some more heavy pressure and it broke again. It has since broken two more times - I think it's time for a new vice.
So, I guess that's the long answer to why I want some new rippers :)
   / Box blade rippers #8
I have Ridgid pipe vises and Wilton machinist vises for many years without ever being able to break one. I have had a couple of cheap ones that are good door stops but not much good under real world use.
   / Box blade rippers #9
Found some slotted rippers on E-bay I'll try to post a link.
REPLACEMENT 3-SLOT BOX BLADE SHANK, 2-1/2" X 3-4"X18", FITS SEVERAL BOX BLADES | eBay
40" WIDE STAIRCASE W/ METAL RAILING (A54757)
40" WIDE STAIRCASE...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A54757)
UNUSED WOLVERINE...
2010 FORD F350 SUPER DUTY SERVICE TRUCK (A54607)
2010 FORD F350...
2014 CATERPILLAR 299D SKID STEER (A52705)
2014 CATERPILLAR...
1998 ford f450 (A53422)
1998 ford f450...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2011 Ram 1500 4x4...
