daybreak1998
Howdy,
Air pressure is subjective. The range between 12-16psi sounds about right.
Filled solution. = do not use straight water. You will want some type of rust preventative. Research the filling solutions. I see your in Texas, so you do not have the freezing conditions others also have to think about.
Look of tire = Large AG tires should sit with at least 3 lugs touching the ground. 18.4-38 radial tire at 14 psi and 75% methonal+water mix sit with three lugs touching. Since they are radial's, they also show some squat (bulging) on the sides.
Use a water capable air pressure qauge.
You can always lower the air pressure when you go to disc.
