Drum Mowers
   / Drum Mowers #1
Cossack1917
SW Pa
JD 2510 Kubota3010 MF65 DB990 JDA(Unstyled) Yanmar D155 Massey Harris 33
Hi guys,
New to the Forum. I have 40 vertical acres here in W. Pa, with about 2 square yards level. I've been cutting about 30 acres of hay with an old New Idea sickle bar, but it is just too slow. A friend mentioned drum mowers, and I am not familiar with them. I've checked online a bit, and I have found 2 so far, Reese, which seems to be centered in New Zealand and an outfit called SFI in Texas. Anyone have any experience with these machines, or should I hold out for a disc mower. I have 3 tractors I use for cutting, a 1959 MF65, a David Brown 990 and a Kubota 3010.
   / Drum Mowers #3
Hi guys,
I am not sure where you are located, however, we have a good used Reese drum mower for sale here in central Ky 42765. The mower is field ready. Price is $2395 picked up here. Ken Sweet
   / Drum Mowers #4
I like the disk mowers myself. I use a New Idea 5410 which has done a very good job. It is made by MF and is now called a MF1330. :thumbsup:
   / Drum Mowers #5
We prefer the disc mowers as well, If all the tractors have a hydraulic outlet at the back? We do stock the model 2050 (7ft) New Fort First Choice for $5795 and we can deliver one to western Pa for around $150. It does require at least 1 remote line out the back of the tractor. Ken Sweet
   / Drum Mowers #6
Cossack, Good morning,
I have researched drum mowers.
They are lighter, less expensive, operate with less HP than disc mowers, and do not need hydraulics.
Brad came up with a good place to start. CCM.
I am saving now to order one next year.
Dave
   / Drum Mowers
You guys are great! Gave me lots to think about. How do the Reese mowers compare to the CCM to the SFI quality wise? I kind of like using the Kubota 3010 on the steep hills because of the 4WD, but at only 30hp and no hydraulics, no disc mower. Looking at the CCM mowers, if I run between the Kubota 3010 and the Massey Ferguson 65, which one should I look at , the 165 or the 190?
Thanks again
   / Drum Mowers #8
Thanks again
The Reese is the Cadillac and has no gearbox to go out. Ken Sweet
   / Drum Mowers #9
The HayMAG Drum mowers are the #1 selling drum mower in the USA and the World. Come visit us at the National Farm Machinery show West Wing 5044
   / Drum Mowers #10
Cossack, I can love my HayMax 165( I assume the HayMag is the same mower?..looks identical). I am on my second year haying 40 ac(we do 3-4 cuts a season) and it has exceeded my expectations. Blade changes(6) take 5 min and are reversible so you get double duty out of them and cost less than 2 bucks a piece. I have a 40 horse HST and can mow in high range if the pasture is smooth.
You will have to tedder your hay as drums and disc mowers pile it up in rows that have to be scattered to dry.
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
2012 John Deere 9560RT Track Tractor (A50657)
2012 John Deere...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
Cat TH407C Telehandler (A51039)
Cat TH407C...
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
2009 JACK COUNTY 130 BBL VACUUM  TRAILER (A50854)
2009 JACK COUNTY...
