Top Link replacement
   / Top Link replacement #1
snpower
Gold Member
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
The top link on my 2360 is frozen; after working on it here and there since last fall I am giving up. The dealer wants $58.00 for a replacement. Can I get a suitable replacement from TSC or is there an upgrade I should consider? I can't swing the hydraulink just yet. :)
   / Top Link replacement #2
Ask your dealer for a take off or a used one. Should be only a few dollars.
   / Top Link replacement #3
Top Links are pretty much standardized...TSC sells 'em for 30 bucks or so.
Either take yours to TSC or measure the barrel (center section) so you get the correct length.
   / Top Link replacement #4
The replacement I got at TSC was better than the original Kubota one in my opinion.
   / Top Link replacement #5
TSC or similar farm store will have your replacement. But, with loose fitting acme threads, you should be able to unstick it. Drill a small hole in the center, fill with diesel or other rust breaking fluid, clamp filled side down in vise, tap with hammer while rotating end, repeat. For extra excitement, apply heat from torch. Philip.
   / Top Link replacement #6
When you drill the hole make it the right size so you can tap it for a zert fitting when your done! :D
   / Top Link replacement #7
My experience is that Kubota uses non standard sized top links. Standard sized ones are a little short or a little long. I ended up with have to switch between two different ones depending on the attachment. That was on a M4700.
Ken
   / Top Link replacement #8
I bought the extended length one from TSC. Using my old Rhino box blade I would extend it enough to use the back blade on the box blade to finish drag my driveways. It was about $40 if I remember correctly. I really didn't like the top link that came with my new MX 5100 and replaced it with the TSC one.
   / Top Link replacement #9
soak it in some PB blaster it should free up.
lube threads with grease or anti-sieze after it's free never seen one this didnt work on.
Well I picked one up from TSC this morning for $20.00. I brought mine along to check the length and size of the hole on the bushing. Got home and... it's a little too wide to fit in the top link hardware (see pic). Guess I can file it down? It was the only Cat 1 they stocked.
2014 TROXELL KILL/TRANSPORT TRAILER (A50854)
2014 TROXELL...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
10 Ft Fork extensions (A50322)
10 Ft Fork...
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
