Gale Hawkins
Super Member
- Joined
- Sep 20, 2009
- Messages
- 8,185
- Location
- Murray, KY
- Tractor
- 1948 Allis Chambers Model B 1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
I have our 1983 JD 310B BH at the welding shop for repair on both buckets.
Not being to do serious welding I was thinking about mounting a thumb with very heavy U bolts. While it is a 60 HP engine the old machine has weakened over the years and has loose pins.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
I think the above will work for my 24" wide bucket that I marked as a possible solution option
They will cut the backing plate to the size I request so I could use a U bolt at each end. Welding if it did not hurt anything would be more simple when looking at the HP/loads i would be trying to pick up.
If it is welded on I could not pull it off too easy. With my physical limitations I am sure I would be using it all of the time however.
Any regrets to mounting a thumb by anyone?
