Angry Beaver project (FEL build)
   / Angry Beaver project (FEL build)
one of these days I want more pics of that loader/backhoe setup...
I might make a BH later on down the road, but for me, for right now the loader is the primary need.
The more I think about it, I will do the joystick control valve, with a power beyond and use one of those two single spool valves I have currently. I'm thinking it could be for the grapple on the bucket, and then angle on the plow... I"ve got an old 6' black blade that I'm thinking abotu converting to a snow plow...but I'm also looking at cheap snowplow setups off of a small pickup or jeep.
   / Angry Beaver project (FEL build) #32
We just use the same spool for grapple and plow. No reason to have two separate ones.
That's what I meant... The joystick for the up/down and curl then the single spool for the plow or grapple...
Was able to get some work done the last couple days. I rebuilt the bucket. I added new pivot mounts and a new curl/dump mount. I didn't have thR tractor at work so I haven't welded in the cross tube yet. I ground down all the rust, rewelded most of the bucket welds and added a new 1/4"x3" cutting edge. I even made a tooth for the one missing on the tooth bar. Then it was wire wheel time, followed by POR-15 metal ready. (spray on bare and rusted steel and turns white. It gives POR-15 a zinc phosphorous coating to adhere to). I used POR 15 chassis black then misted on some true blue while it was still tacky. Another coat followed by some clear and she'll be good forever!
All i have left to do on the fab Is install the dump cylinder crossmember, then it will be ready for hydraulics!
   / Angry Beaver project (FEL build) #35
Looking good! I gotta say I like that blue paint, makes it look sharp. :thumbsup:
Thanks. It was the closest match I could find, but slightly brighter. I'm redoing the whole tractor that color. It's darker than the ford/new holland blue.
Before....
   / Angry Beaver project (FEL build) #37
love your project! Just wondering where you sourced your 3 pt hitch arms and how much bending did you have to do to make them work?
Well, I got all the fab work done this week. I shortened the lift cylinders (removed extra material from the shaft when it was fully retracted), added the boom crossmember, made up a removable front hoop, and welded in the center tie support, as well as the rear subframe. All that is left is running some hydraulic lines and hoses and ordering a joystick valve. I don't know if Im going to tap intothe tractor hydraulics or mount my aux pump setup yet.
this is the rear subframe arms. they mount to the rear, right where the three point pivot shaft is. you can't tell from the pics, but the 1 1/2" cross tube bolts on, and then the front of the arms bolt into the main crossmember
This is the front hoop. It ties the uprights into the front frame crossmember. I still have to drill two holes to boltor pin the removable hoop section into the upright (reciever)
they were huge john deere arms, I believe off a 4500 series... I had to heat the living crap out of them and then used my 25K fork lift at work to bend them... they work, and they were free, but they aren't correct. I want to get the right arms.
   / Angry Beaver project (FEL build) #40
i have the factory arms on mine and was looking to upgrade to something that would handle cat 1 3pt hitch implements. i am making a trip to Valley Power in a couple weeks and hoping he may have something. Mine are twisted up and pieced and welded (badly)back together.
John Deere 4510 (A53317)
John Deere 4510...
1964 Mercedes-Benz 190D Car Sedan (A56859)
1964 Mercedes-Benz...
Informational Lot - Financing (A56435)
Informational Lot...
Case 1083 20ft Corn Head (A56436)
Case 1083 20ft...
2022 CAT skid steer (A55973)
2022 CAT skid...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
