Most cost efficient weedkiller?
   / Most cost efficient weedkiller?
The most cost effective weed killer I know of and use is vinegar. Cheap white vinegar with a tablespoon of salt and a squirt of dish detergent for every gallon. Costs $2.50/gal. Less if you can buy it in bulk or on sale. Use it full strength.
Warning: This is non-selective and kills everything. I use it to clear garden plots, and you can plant 24 hours after spraying. Best thing is it's much safer than most of the other chemicals and I feel a whole lot less concern about it contaminating ground water.
If I want to kill poison ivy and keep the grass, then I use 2,4-D, but for total weed and grass annihilation, I use the vinegar.
Joe
Will have to try that one, thanks. Been a LONG time since I have seen vinegar at $2.50 a gallon, around here it's $4 per gallon or more.
   / Most cost efficient weedkiller? #22
Check at your local farm co-op. At mine 41% glypsophate (sp?) is $13/gal in 2.5 gal jugs.
   / Most cost efficient weedkiller? #23
Containers of glyphosate (aka RoundUp) concentrate mentioned in this thread can be readily obtained for significantly less than that.
By your figures, my 25 gallon sprayer full of weed killer would've cost me $62.50 (25 x $2.50), whereas I only paid $50 or $55 for the entire 2.5 gallons (320 ounces) of concentrate, & I only used somewhere between 10 & 20 ounces of the concentrate for my 25 gallon mix (can't remember exactly how much now).
Vinegar is $1.79 at Sam's club in my region. That comes out to $44.75 for your 25 gallon tank. Like I said, it can be had for less.
Joe
   / Most cost efficient weedkiller? #24
41% is the stronges concentrate i know of. I bought 2.5 galons from Agrisupply for like $35.
   / Most cost efficient weedkiller? #25
Roundup Pro has a 50% glyphosate concentration: Roundup Pro Concentrate (2.5 gallon) 50% Glyphosate
TSC supposedly has a 50% glyphosate product, Groundworks, but I haven't seen it at the TSCs I have visited.
The generic 41% glyphosate suits my needs when I want a non-selective herbicide.
Steve
   / Most cost efficient weedkiller? #26
Glyphosate can be concentrated to 50% without surfactant and 41% with. I prefer the 41% with surfactant. It sticks to the leaves better and is more rain/dew resistant.
   / Most cost efficient weedkiller? #27
if you want to kill the grass all season long get Imazapyr. It will kill all season long, but you cant grow ANYTHING all year long there.
   / Most cost efficient weedkiller? #28
Thanks Brin...what amount of the HD stuff do you use per gallon?
Glyphosate can be mixed at usually from 1-3.5 oz per gallon of water based upon use and target species. It can also be used full strength on stumps and brush after a cutting and stump treatment.
All of these rates are LABLED rates anything else is ILLEGAL. Also i am a licensed aplicator.
   / Most cost efficient weedkiller? #29
I likey 2-4-D oil based for everything but grass. Used as a .5% concentration which is about 1 pint for a 30 gallon spayer.
The mix instruction go from concetrations from .2% up to 1%, could probably use even less now that the tough stuff like thistle is gone.
LV 400 2-4-D
For anything that is green in the wrong spot the Glyphosate stuff is pretty good, $20 for a gallon.
Drexel Imitator Plus 41%
2013 FELLING  SKINNYNECK TA LOWBOY (A53843)
2013 FELLING...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
