Is a fire extinguisher worth it on a tractor
   / Is a fire extinguisher worth it on a tractor #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I was following the other thread on the JD, and it occured to me that if my PT went up, and I carry a fire extinguisher, would I realistically be able to put it out with that one extinguisher. It is such a small extinguisher in the grand scheme of things.
Or if I started a grass fire?
I guess it is better to have one and not find out than to have one and wish I had it but...
Any fireman have opinions?
   / Is a fire extinguisher worth it on a tractor #2
Not a fireman but I would rather have an extinguisher avaialable, and I do...
   / Is a fire extinguisher worth it on a tractor #3
Have one in the truck but for some reason it has never registered in my brain that having one on the tractor would be a good thing. Probably could attach it to the ROPS using ban clamps?
   / Is a fire extinguisher worth it on a tractor #4
better to have one then not have one.
i've used my extinguishers to help other people put their fires out..
   / Is a fire extinguisher worth it on a tractor #5
HERE is a link to my BX25 goodies thread...
It has stuff like the below in it;
   / Is a fire extinguisher worth it on a tractor #6
another bit of FE advice. put a lil masking tape over the nozzle end. keeps bugs out that might plug the tube/end with dirt.. like mud daubbers...
   / Is a fire extinguisher worth it on a tractor #7
Had a wisconsin motor on a heston haybine catch on fire in the middle of a hay field about a mile from the barn, melted the carb and fuel pump off, plastic fuel line from under the seat to the motor melted dumping gas on it - long story short neighbor showed up with some cans of white powder - put some in my hand and threw it on the machine and it went out. Would like to know what was in that red can.
Bob
   / Is a fire extinguisher worth it on a tractor #8
I have mine attached to a metal plate, the plate is clamped to the ROPS. ~~ grnspot
   / Is a fire extinguisher worth it on a tractor #10
I am not a fire extinguisher expert! In the mill I worked at before retiring they had one man whose job was to go around and examine dry powder extinguisher every 4 months. The reason was that the vibration from all the machinery running would compact all the powder down and it would become a solid mass and the extinguisher was inoperative. His job was to turn them over and bang it with a rubber hammer a few times making the mass break back up to become a powder again! So my question is, is a dry powder extinguisher the best for a tractor mounted application? What, if anything, would be better??
is, is a dry powder extinguisher the best for a tractor mounted application? What, if anything, would be better?? :confused:
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A55851)
2024 Wanco...
2017 FREIGHTLINER 114SD TANDEM AXLE DUMP TRUCK (A56129)
2017 FREIGHTLINER...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2015 John Deere 7700A Mower (A52377)
2015 John Deere...
2002 Case SE 750HWT (A54865)
2002 Case SE...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A53421)
2025 GIYI GY-BK56M...
