I found the ultimate chain saw alternative!
   / I found the ultimate chain saw alternative! #1
NHmitch
SW New Hampshire
Bolens G154/IsekiTX1300F
This thing is amazing! I really, really want one! I guess I can dream:)
   / I found the ultimate chain saw alternative! #2
I have something like that they are hand operated lopper shears haha
   / I found the ultimate chain saw alternative! #3
That thing is fine. How much does it cost?
   / I found the ultimate chain saw alternative! #4
:thumbsup: After initially reading you title, I thought that you had captured and trained a Beaver Colony.:)
   / I found the ultimate chain saw alternative! #5
thats good for baby trees, what if you had a real tree?
   / I found the ultimate chain saw alternative! #6
Wow! yep, I could use that. I have 40 acres of trees. Wonder how it would go on Ironbark?
   / I found the ultimate chain saw alternative! #8
Watching the video it doesn't seem to be a problem but how do you control which direction the tree falls? I don't see a grapple hold on to or anything above the shear to deflect the tree away from the machine. I know there is the ROPS and a cage to protect the operator on a skid steer but still do you want the 40 footer leaning over on the cab when you're in it? Videos like this which are essentially a collection of short clips can be misleading in that they can trim/splice footage to only show what they want. You see the shear cut the tree at the ground but you get to see much after that. Yes, you see the tree fall to the ground but how many trees were sheared off to get those dozen or so shots where the tree fell in the direction which presents the product in the best possible light?
   / I found the ultimate chain saw alternative! #9
that might help... how about this one?
Galvanized steel Fence (A53424)
Galvanized steel...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
black Max power washer (A53421)
black Max power...
S/N: 3356916 ***Roof is NOT attached*** (A55853)
S/N: 3356916...
Hyster S50XL (A47477)
