frankroberts
- Joined
 - Oct 24, 2011
- Messages
 - 50
- Tractor
 - MF 50
Do you iron a crease in your boxers?
just wondering...
			just wondering...
just wondering...
a good refurb is a great thing for the tractor. going over it like you are will yeild you with a good worker and looker for decades to come. and is fun...
Nothing wrong with attention to detail, in fact you would not have the interest you have in your progress were you to be simply "throwing it together".
since you've apparently rebuilt several motors in the past, any concerns with the lack of cross-hatching on the cylinder walls. Difficult to tell by the photos, there doesn't appear to be a carbon ridge at the top, which if your oil rings were bad for any length of time you might expect, but I would be tempted to mic the cylinders for round and take a close look at them. I've rebuilt a few motors myself and have always been leary of tightening up a top end without paying close attention to the bottom end of the motor. It can come back to bite you down the road.
I guess I cant believe you are going to this extent and not completing the overhaul of the engine, as long as its apart this far and you are really restoring it why not "make it right"
When the time comes, one possibility I've been considering is installing new rings, then honing the cylinders. It would allow me to properly inspect the pistons and rods, effectively saving money while restoring the cylinders to like-new condition. Assuming that all cylinders are found to be within tolerances when they are measured.
It's easy to say "replace everything", but one has to remember that I have a very limited tractor budget to work with, so I must spend my money wisely.
I agree, and that is exactly what I was referring to. To properly check the cylinders you'll need access to the bottom of the cylinders to measure, which would mean removing the pistons. I would suspect with only around 2000 hours that you'll be fine but with an oil ring possibly going bad on one of your cylinders it would be a shame to bolt her back up to that nicely reconditioned head.
I certainly appreciate trying to remain within the budget, just recommending what I'm sure you've already gone over in your head several times now.
