How I check my torque wrench
   / How I check my torque wrench #1
MillWeld
Gold Member
Durham NC
Ford 641
I got a lot of help on this forum when I was building my trailer including the importance of proper torque on the lug nuts. I bought an adjustable T wrench that clicked at the "proper" torque. I tested it by torquing a 1/2-20 nut at 10 ft-lbs. I stripped the bolt and it never clicked. Took it back equipped to demonstrate this but they had no vise or other equipment so I took my $ and went to Sears and bought one of simpler technology. I tested it too but more accurately.
I attached a "see/saw" arm to a vertical post in the barn. It pivots on a pair of pillowblock bearings and 2 feet away from the pivot point are hooks to attach a bucket filled with weights. I wanted to see if 90 ft-lbs on my wrench was accurate so I put weights in the bucket til it weighed 45 lbs. (2 feet x 45 lbs = 90 ft lbs).
I put the wrench on a nut welded at the pivot point and leveled the "see/saw". The pic shows 95 ft lbs. Not too bad.
It is important to use 2 pillow blocks because I used self-aligning ones. Only one would misalign.
The assembly is well balanced when empty: It will remain stationary in the level position. It was a fair amount of work for a calibration that does not have to be done often but like most of us on this forum we like to do things like this and I know what my lugnuts are torqued to.
Bob
   / How I check my torque wrench #2
I would have thought you would make the bolt head unmoveable (weld the bolt), then hang the weight from the center of the handle with the appropriate weight for the arm length to see if it is accurate. Otherwise there is still some friction in the pillow blocks. But otherwise it is about 5% off. Good enough for gumvent work.
   / How I check my torque wrench #3
I just read up on this topic, by coincidence. Two thoughts. The longer your lever arm, the more precise your calibration. The site I saw recommended 8 feet. Also, they recommended calibrating all the way up and down the range, since the wrench's response may not be linear. They suggested buckets of water as easily adjustable weight.
   / How I check my torque wrench #5
Yes, but how do you calibrate the calibrator? Who watches the Watchers?
The callibrator is cool, though. I want one - thanks for posting that link.
I like MillWeld's idea and edlegault's refinement.
Using both ideas gives you a physical measurement, rather than a reference to compare to.
   / How I check my torque wrench #6
I just use a spring scale and clamp the square drive part of the wrench in a vise. Use the spring scale to pull on the torque wrench 12" away from the head. The spring scale should read the same as the torque wrench.
If a clicker type, I just set it, and see that it "clicks" at the right poundage.
   / How I check my torque wrench #7
Yes, they do go up the line. The lab I work in, we take test equipment in to an internal Cal Lab to be calibrated. They in turn, have to take their equipment in to a higher rated Cal Lab. And on up the line of higher rated labs. It is all traceable.
   / How I check my torque wrench #8
If you press "mem" and the "on" button at the same time, it goes into calibration mode and then IT can be calibrated. But I suspect I am down to feet and pounds at that point. All I wanted it for was to make sure my set of wrenches are right, and the calibrator came with a calibration certificate for itself, and I will quickly have my wrenches calibrated.
   / How I check my torque wrench #9
The certificate of calibration will expire eventually. Still for most of our purposes it is good enough.
   / How I check my torque wrench #10
This was discusses not too long ago.
There are palces that will calibrate torque qrenches. Sometimes even the Snap-On truck. Otherwise if you google/search in your local area, often there are calibration houses that have the strain gauges to do the measurements.
Also, most torque wrenches are accurate in the middle of their range. They fall off the bell curve as you go ove/under the middle of thier range... If you meaure 20ftlbs on a 150ftlb torque wrench, it will not be in it's more accurate range.
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
2019 International DuraStar 4300 24FT Box Truck (A56858)
2019 International...
THREE POINT WYLIE SPRAYER (A58214)
THREE POINT WYLIE...
2008 Ford F-450 Crew Cab Utility Flatbed Truck (A55973)
2008 Ford F-450...
2012 DOOSAN G25 GENERATOR (A58214)
2012 DOOSAN G25...
NEW Wolverine Skid Steer Trencher (A59000)
NEW Wolverine Skid...
