Dodged a bullet with our house AC tonight!
   / Dodged a bullet with our house AC tonight! #1
s219
Super Member
Virginia USA
Kubota L3200, Deere X380, Kubota RTV-X
So we were finishing up dinner, and my wife asks "is it hot in here?". As soon as she said it and I realized the AC was silent, I started sweating. Went outside while still chewing my last bite, and the outside compressor unit was just humming, not running. I poked the fan with a stick, and it slowly spun up, but the compressor was not kicking on. Crap! At 8pm, I knew things were going to be dicey whether I did the repair or we called someone in. It didn't help that it was triple-digit hot today, with heat index of 116F. At 8pm, it was still hot and my shirt was soaked just standing out there.
We got ahold of one repair company, and it took about 30 minutes before their dispatch got back to us and told us they were booked solid through 1am with service calls! Called another place, and same story, but the guy asked me a couple questions and immediately came to the same conclusion I had suspected, that the dual-capacitor went bad. He check with his field techs, and one was in the area. Since it was likely a quick fix, they sent the guy over between bigger jobs, and he got here about 9pm.
I had setup a work light near the compressor unit, and pulled off the access panel. The capacitor was definitely swelled up a bit. The tech arrived, took one look, did a quick test with a multi-meter, and agreed that was the problem. He swapped a new capacitor in, and everything fired right up once we cut the power back on. Boy, did I feel relieved -- not only was that saving the day, but we were now looking at a repair bill of about $200 rather than thousands for a new compressor unit! The guy pressure tested the unit and watched the gauges for 5-10 minutes while the system started cooling. He added about a pound of refrigerant (not bad for a system that hadn't been serviced in 12 years).
I feel like we dodged a real bullet. Last time we had a failure it was the blower fan in the air handler, and it took me about 2 days to roundup a new motor and capacitor for that. At that time, temps were only in the 90s, and it was still tough. Same for the instances when we've been without power for a few days after hurricanes -- that has always been temps in the 80s and 90s. I don't know how we would have dealt with no AC for days in this triple digit heat. Really makes me wonder how people dealt with extreme hot weather in the old days before AC. I assume they didn't have tight houses, and maybe took more care with house design to maximize shade and natural ventilation.
Interestingly, the repair tech told me we got priority tonight because we only have one air conditioner for the whole house. Some of the other service calls were for houses with dual zone but only one failing unit, so the repair company lowers their priority. Seems like a real fair way to sort customers when it's a busy night with high temps. This guy seemed to think he would be working until 1-2am, but he said he was glad for the work.
   / Dodged a bullet with our house AC tonight! #2
If he added freon, you might have a leak.
   / Dodged a bullet with our house AC tonight! #3
I think this heat is really giving these guys a lot of work. A neighbor of mine has a heating and cooling co., and he is real busy. I talked to him a the grocery store last week, at 8 pm, he had been working since 6 am.
If he added freon, you have a leak.
I plan to check the pressure in a few weeks to see. We'd really need to know a history of the system to really say if it's a leak -- could have been 1 lb low the whole time for all we know. It has been cooling the same for the whole 12 years, with no noticeable change, so I am thinking that's the case. The whole system holds 14-15 lbs of refrigerant, so I suspect it would have needed a lot more than 1 lb if there was a long term leak or even a recent failure. We'll see when I retest it.
   / Dodged a bullet with our house AC tonight! #6
That's great that you got it working, this is not the time to be without it.
   / Dodged a bullet with our house AC tonight! #7
Are you sure it holds 15 lbs???? Thats a lot of freon.
   / Dodged a bullet with our house AC tonight! #9
For the same reason you always find what you are looking for in the last place you look.
   / Dodged a bullet with our house AC tonight! #10
Why do air conditioners always fail when its hot out and heaters always fail when its cold?:rolleyes:
MoKelly
cuz no one uses ac when its cold out and no one uses heaters when its hot?
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
