3PT Lower Connection Spread / Quick Hitch
   / 3PT Lower Connection Spread / Quick Hitch #1
Artisan
Monrovia, California
Kubota BX25
Gents does anyone know of an off the shelf bolt on adaptor
to spread the lower connections on my Gearmore AS Series tiller
to the span of a quick hitch? I guess I can weld on some ears and
do whats necessary but....thought I would ask. Here is what I have.
   / 3PT Lower Connection Spread / Quick Hitch #2
They would have to stick out at least 6", maybe a hair better and
the leverage from such a long pin would bend stuff I thunk.
The QH is 28.5" Center to Center.
The OE Brackets are like 22.25" Outside to Outside.
I am working an idea to buy 2 more of the brackets and making
the backside clamps.
Darn it, how to make those brackets.
I guess I could get a piece of .25" x 1.5" angle and weld ears on it...
Sure would be nice ot find something close and make this a bolt on mod!
   / 3PT Lower Connection Spread / Quick Hitch #5
Who has a brake and can whoop me out two of these babies?
(I have not read your latest bcp, on a mission here...)
The 3rd thought isn't a bad idea...
I await a price on the OE brackets and maybe
something close to the clamp I need will pop up.
That would look as close to store bought as I could get I think.
   / 3PT Lower Connection Spread / Quick Hitch #9
Or cut the square tubing along one corner, and carefully using a torch, bend the 2 sides adjacent to the cut out to serve as ears.
   / 3PT Lower Connection Spread / Quick Hitch #10
i say U bolt. and a some extra nuts and a washer that fits the U bolt.
tightening up the nuts. and it will cause the 2 washers to bend right around the square tubing on tiller.
or skip the extra washer and 4 nuts, and just go for a generic U bolt, with a washer, and 2 nuts. ((suggest adding 2 more nuts. so the nuts do not spin off / back out on you, threads shear off))
if the washers or U bolt bends as you tighten the nuts, keep on tightening till you think you got them tighten enough they will not bounce loose. (may need to get off tractor a couple times to check) and tighten up. on the first time tiller is used with Q/A after that should be trouble free.
edit ok re-looking back at your pictures, the edit picture of mine most likely would not work, but just a generic U bolt by itself with a washer and a nut on each leg. and just keep tightening the U bolt and let the U bolt bend how ever it wants to bend.
have done it a few times on some pipe gates that look kinda like a P. and on a few other things. it holds, that is all i care about. bending of bolts well just will have to live with it.
2006 Caterpillar 315C L Hydraulic Excavator (A55787)
2006 Caterpillar...
UNUSED Hydraulic Thumb Attachment (A47477)
UNUSED Hydraulic...
Transfer Pump (A53316)
John Deere 510C Turbo (A47477)
John Deere 510C...
2016 Dodge Charger SRT Hellcat Sedan (A55758)
2016 Dodge Charger...
1967 Ford F100 (A47477)
1967 Ford F100...
