Framing a house: 2X4 vs 2X6
   / Framing a house: 2X4 vs 2X6 #1
Chain Bender
Kubota L3200
Hope to start sawing logs in the next week or two for lumber to frame my son's new house. I know most houses are framed with finished 2X4's, but I believe that is because of the cost of 2X6's. I've got plenty of clear pine to cut all the 2X6's I would need. I live in NW FL and the winters are mild and the summers really hot for 2 months. Would there be any real "thermo" advantage to using 2X6's? I know structurally it would be stronger than 2X4 outside walls.
Anyone here ever frame a house with rough cut 2X6's?
tks in advance,
Chain Bender
   / Framing a house: 2X4 vs 2X6 #2
Hope to start sawing logs in the next week or two for lumber to frame my son's new house. I know most houses are framed with finished 2X4's, but I believe that is because of the cost of 2X6's. I've got plenty of clear pine to cut all the 2X6's I would need. I live in NW FL and the winters are mild and the summers really hot for 2 months. Would there be any real "thermo" advantage to using 2X6's? I know structurally it would be stronger than 2X6 outside walls.
tks in advance,
Chain Bender
I believe in some nothern states it is now required to frame with 2x6.
Wedge
   / Framing a house: 2X4 vs 2X6 #3
Obviously, 2x6 construction will give you much more space for increased insulation installation. I don't think that's your problem. I framed a workshop in DeLand Fl with rought cut pine 2x4 that I stacked, dried and had pressure treated. When the inspector came for framing inspection, he said "no heat
I see". I asked him what he was talking about, and he showed me in the Florida Bldg Code, that unless framing lumber has a kiln dried stamp on it, you cannot heat the structure. Says the heat brings the bugs out of the lumber. I argued that it had been pressure treated, didn't cut any ice, had to agree that there would be no heat. Had to wait a couple of months after final to install the heat and air, so be careful.
Boy don't I hope that has changed. Wouldn't matter if it was a 2X4 or a 2X12 if that's the case. Not sure where the nearest kiln is around here. But I will be tryng to find out in just a few minutes.
Tks for tks heads up. This certainly changes the price of a new house!
C. Bender
   / Framing a house: 2X4 vs 2X6 #5
Two things to worry about (1) The lumber is properly dried, otherwise it will warp and twist and really mess up the house, and (2) that the lumber dimensions are standard 1.5" x "5.5", otherwise this could make the construction project more difficult. Otherwise 2 x 6 is good for strength and because you can put more insulation in there.
   / Framing a house: 2X4 vs 2X6 #6
it's code up here since the 80s I think. 2x6's on outside walls.
Its nice actually, lots more insulation and stiffer. If you have the means do the 2x6's - but make sure hey are 5.5 otherwise it will become a pain when you start with door frames and so on.
sounds like the biggest thing will be the kiln drying problem though.
   / Framing a house: 2X4 vs 2X6 #8
I built a new house almost two years ago (December 2010). I used 2X6's for the outside walls instead of the 2X4's originally called for in the blueprint. According to my architect this gave me some structural advantages on the spans along with it met the requirements for my insulation requirements (1.5 inches of foam and then the remaining in wet cellulose). The insulation characteristics worked out well the last two winters (2010 and 2011) with the Geothermal unit, which is completely dependent on the homes insulation, kept the house very warm for no more than $50 per month in electricity to simply run the fan and heat-pump.
   / Framing a house: 2X4 vs 2X6 #9
When I built my 24' X 36' seasonal home, I went with 2x4's as it is heated with wood, unheated when no one is there, and framed with 2x6's would have cost me 20 sq. ft. of floor space. Just my :2cents:
   / Framing a house: 2X4 vs 2X6 #10
Here in VA with our milder winters our builder didnt think we would see that much of a savings, BUT I wish we would have used the 2x6 for at least the outside walls..
I like 'dschuffert' idea of the 2x6 with some foam insulation.. I wish we had also done some foam insulation
Brian
2006 Ford F-650 Crew Cab Aluminum Landscape Dump Truck (A55852)
2006 Ford F-650...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
1065 (A53342)
1065 (A53342)
Year: 2014 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 59,333 Plate: Body Type: 4 (A56859)
Year: 2014 Make...
2012 Ford Fusion Hybrid Sedan (A55853)
2012 Ford Fusion...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
