milkman
Elite Member
- Joined
- Sep 22, 2001
- Messages
- 3,555
- Tractor
- BX2200, BCS 735
Milkman--
Do you see bad camber on the camo RTV or the blue one? The blue one is mine, and it definitely has (had) a camber problem. The camo one belongs to the OP (jpinkston70) and I can't see a camber problem in his pic.
So I agree he needs to check his toe. He should be able to get several thousand miles out of HDWS tires (though he has ATV tires now) on pavement with good alignment. With my bad camber, I still got 900 hours (~2500+ mi) on pavement before I went thru the cords.
kevin
I can see the positive camber in your second photo, is that before or after the fix? It's hard to tell from photos, so if taken from floor level, they would probably look different. The old VWs had a lot of camber in the rear wheels and they still got a lot of miles on the tires.
