Buying Advice L, M, or MX series? Can you offer guidance?
   / L, M, or MX series? Can you offer guidance? #71
I guess you are relying on loaded tires with cast centers on your 7040 for ballast... You're going to kill the front axle unless you start using proper rear ballast on the 3 pt hitch... Just sayin.
:thumbsup:
   / L, M, or MX series? Can you offer guidance? #72
I am going to have a little fun here, but this post will probabally get deleted.
I didnt know just how deep this went with case245 until I started searching. Quotes are ALL from him in various threads
THE OLD CASE 21hp I RAN TILL 2005 Was A BETTER TRACTOR THAT HAD 11K ON IT NEVER EVER CHANGED THE ENGINE OIL
:eek:
im still up in the air bout the reiableity of the Kubota
Seriously? Sure, the kubota will last 11k if you never change the oil:laughing:
the kubota is no camparo to the 245 case ih we put 11k on the kubota wont last near as long im not inpressed with it at all i hate it i shold of bought a skid steer
A Skidloader wont last 11k when neglected either. But you are right, you should have bought one. (or anything other than a kubota)
the farmer i work for has a massey 362 its 55hp idk but told kubotas are crap id like mine it only lifts 200ibs more then the old caseih 245 21hp 3 cyl 60 cu in 2000ibs mach this thing 38hp an only wiegh 600ibs more c om n 200ibs more lift i cant drag loggs either the case did more
The farmer is an idiot. And lets compare, 2000lb case and 21HP, vs 2600lb kubota and 38 HP. The case can drag more???? Gee I wonder what could be wrong with the kubota?? Ballast??MAybe???
bluegill not knowi how to use a small compact c om i put 11k on a case skidin thosands of logs n tilling with 5 footer
Could have fooled me:laughing:
my loader welds cracked at a few places i got the tractor two weeks ago its a kubota 7040su
:confused3:
i going thourgh the dealer now i hope i dont to go the kubota it self i been moving heavy eqiupment since 8 years old running at 11 i never broke the case compact
very suprising
i have an 7040sud fel 4x4 loaded rear tires cast center can i add more weights to the cast centers they have square holes in them if so how much more can i add the back end was off the ground today
i was going to bolt more weights to the cast centers but i didnt know if the rear axle could handle it
Someone with your experience around equipment should know that wheel weights dont effect the axles
u guys judge me u do know me my back ground been on run equipment since 7 yrs old
It sure dont show it by your posts.
IMO, you should get rid of that junk kubota. And get something....anything but a kubota. You are giving them a bad name. You do know case still makes tractors right???? Get a CaseIH of whatever model you want, beat the pi$$ out of it, and never change the oil for 11k and see if you still think case is all that.:laughing:
   / L, M, or MX series? Can you offer guidance? #73
:eek:
:confused3:
very suprising
Sure wish I had me one of them thar old Case's with over 11,000 hours, on it,, If I did I would never have to change oil..:).. Think of all the money that was saved by not changing OIL:shocked: That's a bunch of coin! Yeah, them crummy Kubota's can't hold a candle.... yeah my thread will probably get whacked too!..
James K0UA
   / L, M, or MX series? Can you offer guidance? #74
James K0UA
I wished you would have talked him into a kioti:laughing:
   / L, M, or MX series? Can you offer guidance? #75
I wish he had bought a Case instead of either a Kubota or Kioti:D Think of the saved money in oil and filters:shocked:
James K0UA
   / L, M, or MX series? Can you offer guidance? #76
:eek:
:confused3:
very suprising
:drink:
We have seriously sidetracked the OP's thread...
   / L, M, or MX series? Can you offer guidance? #77
My next question is one easily answered by a dealer, but it's 10pm here in SE Ohio! :licking:
When you add a loader to an L, M, or MX, I assume these model tractors already have the mid-mount remotes ready to hook up the FEL? The joystick comes with the FEL package I assume?
On the GrandL, the joystick is built into the station, and the FEL hydraulic connections are built into the station. So, if you do not get the FEL, all the necessary parts except the brackets/mounting points are already there. Philip.
Thank you!!!
...for jumping back on topic. I'm learning a bunch here.
   / L, M, or MX series? Can you offer guidance? #79
koua were u there do u see the hour meter turn over from 9999.9 hours to 0 again no i was on the tractor when it happen
   / L, M, or MX series? Can you offer guidance? #80
Lets leave this thread alone, we are not adding anything to it..
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
2016 Nissan Altima 2.5 Sedan (A55853)
2016 Nissan Altima...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
CONTACT INFO (A53084)
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
