6sunset6
- Joined
- May 6, 2007
- Messages
- 1,057
- Location
- SE NY
- Tractor
- NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
I need a bigger one. I have 9000 sf of patio blue stone and underground gutter run off pipes to clean. Plus the cedar siding on the house. The PW I have is 500 psi 1.5 gpm. I need (want) 4000 psi at 4.5 gpm. ( Thats 10 hp).
Too big for an electric motor 1 ph and I hate gas engines. I only limit myself to 4000 psi because that is what all my hoses are rated at. So for those of you you have watched me calculate the pros and cons of using tractor power for attachments, while the log splitter failed the test ( need the tractor for transport when splitting and I need a lifter), the logging winch passed. The pressure washer seems like it would like tractor power. ( relatively short use once or twice a year and don't need the tractor when pressure washing). Tractor has 10 hp at rear aux and 27 hp at pto. As much as I like hydraulics This would be a pretty high speed motor , at least 1000 rpm and probably faster 1750 . Would probably be new and pricey, although I have not looked. The PTO looks better. Northern Tool has a unit ready to go at $1700 plus shipping About $100. Why it has to go truck freight is beyond me, it weighs 66# and could brake down . It is drop shipped from the factory.
It is made by Comet. They attach the pump to a gearbox that will run off 540 rpm PTO . On a 3 point frame , no PTO shaft, which looks like 1 3/8 x 6 so maybe another $150 . Comet also makes an adapter that would allow the same unit to run off a mid PTO at 1000 rpm. I like to squeeze the nickle till the Buffalo poops(splitter 4k build vs 13k plus buy. logging winch was about half). So I looked at building my own but the pump itself is around $1000 then a relief valve , gage speed increaser of some sort and frame to put it on starts to get close to the purchase price new. I looked at mid point 1000 rpm with a pump to match but derating the pump rpm required a bigger pump plus longer pto shaft and then mounting ( QA would be a bad idea) cost comes up to the same as the Northern unit. So if I am going to to this I would be looking at that unit. But how come nobody else has one like this?
