1/2 mile of fence
   / 1/2 mile of fence #1
Timm250
Gold Member
Western KY
Kubota M6800 w/1600 hrs., Case Farmall 95 w/800 hrs., Long 2510 w/1100 hrs, Cat 236B2 Skidsteer w/1000 hrs
I have been cleaning out about 1/2 mile of fence row on our place. The old fence was put built in about 1970 and trees had grown through the old fence to the point that they were about 1-2' apart on the entire fence row. There was a drainage ditch running next to the old fence row that was almost completely filled up which needed to be cleaned out as well. It now has a new 4 strand barb wire fence on this side of the property.
Taking out the trees
Cleaning out the drainage ditch
New fence posts
And the fence
   / 1/2 mile of fence #2
Looks like you put a TON of hours in with this project.
You did well, be proud!
   / 1/2 mile of fence
Thanks!!
We have worked on this all summer. Most of the weekends & any time off from my day job this summer were spent on this project.
   / 1/2 mile of fence #4
Nice. Those corners are definitely NOT going anywhere.
Cattle ?
   / 1/2 mile of fence #5
Very nice. It looks to be perfectly straight. What animals are you enclosing in there?
   / 1/2 mile of fence #6
Very nice. I really like how bulked up your corners are!!!
Eddie
   / 1/2 mile of fence #7
Nice job - fencing is always "hard yakka"
Interesting way you've braced the strainers/corners & run the wire rathet tensioners.
   / 1/2 mile of fence
   / 1/2 mile of fence
Well done. :thumbsup: Did you encounter many rocks?
No rocks. This is bottom land. In some places after you get down about 5' there is a lot of small pea gravel. The largest is probably about 1-1.5"
2007 STERLING AT9500 SERIES SEMI TRUCK (A55745)
2007 STERLING...
2018 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2018 ALLMAND BROS...
2016 Sakai SV540 Padfoot Compact Roller (A54865)
2016 Sakai SV540...
2012 MACK CXU613 DAYCAB (A55745)
2012 MACK CXU613...
2005 INGERSOLL RAND SD-70D TF SMOOTH DRUM ROLLER (A52706)
2005 INGERSOLL...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
