Kerosene in tractor
   / Kerosene in tractor #1
Slab
Ny
Yanmar sc2400
Ok or bad to use it as engine fuel in an emergency?
   / Kerosene in tractor #2
It would probably run if it is hot enough. Them old duel fuel tractors ran on it.
I am sure others will have different thoughts and will probably end in a heated discussion.
   / Kerosene in tractor #5
Kerosene is thinner and will do less work per gallon than diesel. Kerosene is also more expensive than diesel. I would use kerosene in my tractor in a pinch.
   / Kerosene in tractor #6
Kerosene and #1 diesel are generally equivalent. In refining, kerosene/#1 diesel is the portion that boils off right after gasoline. It has less lubricity and a lower heat content than #2 diesel. The 1928 Case model CC I have in front of my place has a 2 fuel tank system. It starts and warms up on gasoline, but then is switched over to lower cost kerosene which runs through a heat exchanger to warm the fuel before going into the carburetor. I'd try to limit use of kerosene to prolong fuel pump and injector life .
   / Kerosene in tractor #7
Sure in an emergency, I would.
Before settling on stanadyne we used kero to condition our winter diesel.
   / Kerosene in tractor #8
I would add some 2 cycle outboard oil to the fuel for added lubricity so tyhe injection pump isn't damaged.
Perhaps at a 50~100/1 ratio for peace of mind.
   / Kerosene in tractor #9
At the local airport they run all the diesel powered equipment, including a large bucket loader, on jet fuel.
   / Kerosene in tractor #10
yeah.. I'd run it if I had to.. and add a lube to it.. it's more $$ than diesel #2 here.. so I doubt I'd be running it.. but you never know.. If I got some gave to me.. I';d burn it for sure..
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2007 FORD F650 XL SUPER DUTY FUEL & LUBE TRUCK (A51406)
2007 FORD F650 XL...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
