slowzuki
Elite Member
- Joined
- Sep 19, 2003
- Messages
- 4,100
- Location
- New Brunswick, Canada
- Tractor
- Kubota L5030 HSTC, MF 5455, Kubota M120, Allis Chalmers 7010
I've had 2 types of Michellin radials and one type of Firestone radials.
Check the inflation against the tire manufacturers load table. The sidewall will look the almost the same for a wide range of pressure for under to over inflated. The owners manual doesn't have the radial pressures for any tractor we've owned. If you don't have to add and drop your front weights, run the lowest pressure.
Make sure the tires aren't loaded. Radials ride terrible when loaded. I had one tractor arrive from the dealer and they had loaded one side but not the other without asking.
