Changing Antifreeze L3400 - Capacity is short
   / Changing Antifreeze L3400 - Capacity is short #1
Kubota L3400
I just changed the antifreeze in my L3400. Did it per the Kubota manual. The amount drained was only a gallon and it only took a gallon to fill it again. Kubota Spec says it should be 1.6 gallons. Seems obvious that there was a 1/2 gallon left in the engine block. So how do you drain the block and how come Kubota doesnt tell say how to drain the block?
Any thoughts?
   / Changing Antifreeze L3400 - Capacity is short #2
Change it again in the spring. Assuming it will get rebular use over the winter, it will be well mixed by spring.
   / Changing Antifreeze L3400 - Capacity is short #3
This is just an hypothetical idea.. You could either forget about the .6 gallons and go on. or you could do this:
Go buy undiluted antifreeze not the 50/50 mix stuff. Then drain the gallon out, and put 1 gallon of water in. Run engine a minute or two, stop and drain this water/diluted antifreeze mixture out and discard. fill with water, run for a bit, drain and discard, do until the drained looks like water. Then add .6 gallons of pure antifreeze,into the tractor take the remainder of the jug, and mix 50/50 with water, and fill up the tractor with this.. Now you have a 50/50 mix and no appreciable amount of old antifreeze in the block. OR.. you could get a flush and fill kit to flush out the block, and then fill as per my last instruction. Do as you see fit.
James K0UA
   / Changing Antifreeze L3400 - Capacity is short #4
I changed mine about a year ago, had the same problem. I did pretty much what James suggested and kept adding water and running it briefly until I had almost clear water coming out. Then added pure AF and some water to get the right mix. I did have to drain a little off and adjust the mixture a couple times to get it exactly where I wanted on the freeze tester.
Be careful not to get it too hot between refill and drain, the last thing you want is cold water going into a hot engine block.
Sean
   / Changing Antifreeze L3400 - Capacity is short #5
I have five different Kubota's, all different models with different engines. On everyone there is a rubber hose that connects to the right side of the engine (when sitting on tractor), I remove the hose clamp and pull the hose off, that drains the entire block, I also use it to back flush the block using a gargen hose.
Thanks all for the advice. I guess they'll all work. I like 2007's the best. My tap water has a lot of lime in it so I always mix distilled water with the antifreeze. That would make it a bit easier on the amount of water I need.
Thanks again!
   / Changing Antifreeze L3400 - Capacity is short #7
Maybe the .6 gallons is to fill the recovery tank up between L and H?
   / Changing Antifreeze L3400 - Capacity is short #8
I think there should be a drain on the block.
   / Changing Antifreeze L3400 - Capacity is short #9
Interesting that the L3400 DT (gear) has no recovery tank, while the HST version does... I have no idea why they are different though.
Sean
   / Changing Antifreeze L3400 - Capacity is short #10
Weird.
So the radiator cap just vents outside?
2005 IC Corporation PB105 School Bus (A54814)
2005 IC...
Case 1083 20ft Corn Head (A55301)
Case 1083 20ft...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
LOAD OUT AND SHIPPING (A54865)
LOAD OUT AND...
