2028 century hydraulics quit working
   / 2028 century hydraulics quit working #1
rogerdodger
skiatook oklahoma
2002 century 2028
i have been using my tractor moving tree limbs when all my hydraulics quit working front end loader and box blade will not lift i changed fluid and filter still nothing any clues to what went wrong and how to resolve?:confused2:
   / 2028 century hydraulics quit working #2
Check your pump to see if it's turning.
Use a hyd gage and check your pressures.
thanks j_j my pump on this model is gear driven and also runs a separate pump for power steering which is working fine but has a seperate reservoir
   / 2028 century hydraulics quit working #4
Is it possible you could have hooked one of the hoses with a tree branch and partially unplugged one of the quick disconnects.
   / 2028 century hydraulics quit working #5
Remove a complete QD fitting from the hose going to the first QD and place in a bucket and see if you have hyd flow.
If so , check the hyd pressure.
took high pressure line off feed block to front end loader nothing there guess pump went out:thumbdown:
does anyone know what make the hydraulic pump is on a century tractor 2028? cant find the name on pump
   / 2028 century hydraulics quit working #8
Check the spline, keyway or coupler to make sure it's turning the shaft
Pix..??
Didnt know if i wanted to tear it apart if i couldnt find another pump if i needed it
   / 2028 century hydraulics quit working #10
I looked at the parts breakdown on the bBranso sight and all it says is 13 cc. I have looked at my Branny 2400 and can not find a number on it either. I would suspect the drive shaft is spline so it is possible the splines are worn or a coupling has slipped. I couldn't tell were or how the pump is mounted but if out in an accessable area where you don't have to drain the tranny I would remove the pump and look for obvious damage. Gear pumps are usually pretty tough so suspect something in input drive broke.
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
